Trouble getting mulcher head to zero on Rayco c140
   / Trouble getting mulcher head to zero on Rayco c140 #1
ALittleDirtWontHurt
VIRGINIA
Gyrotrac GT-25, Terex PT110 Forestry, New Holland TC33, Kubota KX080, Terex PT30, Rayco C140, Polaris ATP 500
My rayco c140 wants to spin the head slowly all the time. The external adjustments have been done and still having trouble. My dealer suggested getting it to a hydraulic specialist and that it's something internal. It's difficult to start with power being sent to the head while cranking, not to mention dangerous. Any ideas??
   / Trouble getting mulcher head to zero on Rayco c140 #2
Mine done the same thing once, I finally narrowed it down to the hand lever to engage the head, the cable got out of whack.
Hope it's the same for u
   / Trouble getting mulcher head to zero on Rayco c140 #3
You can stop that happening by adjusting the outer cable at the bracket just in front of the muffler. It's fiddly but with a little patience you'll get it right, just don't do it when the tractor's hot. If there is no more adjustment, a long steel bar and a good sized hammer will do the trick. :thumbsup::D. Now If all that didn't work then remove the cable off the actuator arm on the top of the pump, ( it's on a spline ) and rotate the arm one notch at a time, reset the cable and see how it goes. How many hours has the machine done?
It has 1700 hours, but looks like a tough 1700.
   / Trouble getting mulcher head to zero on Rayco c140 #5
Maybe time to start a budget for the pump replacement. Over here in Aust most of them blew the cutter pump to pieces between 2-3000 hours. When it does go (no if) replace it with a Saur Danfoss pump, they are far superior
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
