JD 650 no power to fuse block or lighting
   / JD 650 no power to fuse block or lighting #1
Bigr1959
Fate,TX
JD 650, MF 50
I just put a new key switch on and rewired several things. Tractor fires right up but I am not getting any power to fuse block or to lighting.
Any idea's? Is there a dedicated ground maybe I missed?
Any help greatly appreciated.
Mark
   / JD 650 no power to fuse block or lighting #2
I have a PDF of the Tech manual you're welcome to, it has all the wiring.
Shoot me your email if wanted
Joe
   / JD 650 no power to fuse block or lighting #3
If all the electrical worked well (lights, etc) before you rewired it, then I would have to suspect the rewiring that you did or the part(s) you replaced. I would suggest to go back and doublecheck all of that work. Although, I suspect it may not be so easy now since it could be different from the way it was originally. If that doesn't seem to be a problem, then maybe the new switch is just different and not providing 12v to the block? If you are certain all that is correct and not the problem, maybe you left a connector unplugged, or accidentally left a wire loose somewhere??
   / JD 650 no power to fuse block or lighting #4
Joe
Hey Joe, I know it's been a few years since this post but I just purchased a JD 650 and could really use a copy of the tech manual. I'm trying to get it up and running.
   / JD 650 no power to fuse block or lighting #5
Send Joe a pm, and include your email.
Click his username to see how to send the private message.
Welcome to TBN
   / JD 650 no power to fuse block or lighting #6
Mark
sounds like the time I purchased a new key & switch for my cub and the new switch wouldn't work so I put the old one back on. May have a new junk part.
Chevrolet 2500 Flat bed (A56438)
Chevrolet 2500...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
Rooster Weathervane (A55853)
Rooster...
John Deere 1025R (A53317)
John Deere 1025R...
2015 CATERPILLAR 259D SKID STEER (A60429)
2015 CATERPILLAR...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
