bank trimming?
   / bank trimming? #1
ykpowers
hillsville va
49 ford 8n
I have several areas on the property that I have been trimming by hand, but that may not be the best way....
Case:1 small creek about 4' wide. It has channeled down about 2 Ft would a sickle mower work well to cut this flush across?
Case 2: 45deg bank with road directly below and on top. Can you run a sickle at a 45deg angle or does it have to be flat?
   / bank trimming? #2
Both of your cases can be satisfied with a sickle. However, you will need a newer one that is BELT driven. Most, if not all, belt driven sickles can work from 90° up to 70° down. The old Pittman driven sickles don't have the working range you need. Some used ones that are capable of doing the job .... JD 350, Case/IH 1100, Ford 915 and there are others.
   / bank trimming? #3
Would this idea work for you? Unfortunately I'm not skilled enough to rotate the image but I'm on about a 45 degree slope with no danger at all of tipping.
   / bank trimming? #4
Man - what a let down. I thought this was going to describe ways to recoup funds that the banks charge. Sorry
   / bank trimming? #5
Maybe it should be. Sooner or later that would pay for a new sickle mower.
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
Polaris Side by Side (A50324)
Polaris Side by...
1263 (A50490)
1263 (A50490)
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
