Tc40 a left console removal
   / Tc40 a left console removal #1
Gfagel
Millersburg, Michigan
New holland tc40a
My shuttle lever snapped off a few days ago. I have a replacement
On order. Am trying to figure out how to
Remove the left console. I have the two rear bolts removed
And suspect there is another bolt but don't know where it is. Can some one help
Thanks in advance
Gary
   / Tc40 a left console removal #2
Raise the hood and on the outside edge of the firewall there are two bolts that screw into the console panels. I think they are the same size as the rear bolts. When replacing, be sure all are aligned and then tighten. and welcome to TBN
Thank you shuttle lever arrived now all I have to do is get the hood latch to open.
Always sticks at the worst time.
   / Tc40 a left console removal #4
Use a really long socket extension on those bolts in the firewall - makes it a bit easier....
Next issue down to removing the pin. How do you get the pin
Out to replace the shuttle arm.
   / Tc40 a left console removal #6
Looks like a roll pin. You need a 5 mm drift to knock it out. Maybe a little rust solvent also.
Thank you all who guided with this repair
Some liquid wrench a few chosen words and
A few hits on a drift pin. Was able to get it back up and working
Thanks again
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A51694)
2014 Glasstream...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
