arrow
Super Member
Thanks for your input. After reading through it and looking at the options, I am coming to the realization (as Brian mentioned) that it is difficult to meet my current and potential future needs with a one time purchase and stay on budget. For that reason I am only going to focus on my current needs at this time. I'm going to be with my current property and machine most likely for 12 years minimum. I'll can figure out the future later. See - you guys are so good that you answered a question i didn't even know I had!
So now my questions are:
1. End plates vs. hydraulic angle. If I got end plates, I doubt I would want to take them off and on all the time but I suppose they would negate the hydraulic angle. Question: Which is more useful for twice a year maintenance of a gravel driveway, an blade with hydraulic angle or a blade with end plates?
2. For my current tractor only (45hp 4WD), would the Bison NVHA be suitable in either 7 or 8 ft width? It's about 400 pounds and has a 60hp rating (I didn't see it specified if that is 2wd or 4wd)
3. Any others that I should be considering given that we are now only sizing for the current tractor?
I don't mean to throw a wrench into this but what worked for me way better than a scraper blade to maintain gravel drives was a box blade with scarifiers. Certainly the snow plowing aspect of the rear blade is an important one but trying to fix up a hard packed gravel drive I found rather an effort in futility with the rear blade. Saying that, some people call loose stone -"gravel". If that is the case, a rear blade would certainly help to crown the road and dredge up shoulders.
I would still maintain that a high moldboard 7 footer will do you quite well. For snow removal, an end plate would also come in handy.
To answer your question, nothing will beat the efficiency of a hydraulically controlled rear blade that you are manipulating from your seat.
So here is the summary: If you are removing snow and have a gravel stone drive, get a blade that you can add hydraulics to. If your drive is "hard packed" gravel, get a simple rear blade that you can manually set for snow plowing and then invest in a box blade for maintenance.
Brian, (Mountain view Ranch) has done some excellent work on his roads with a box blade. Perhaps he can post some of these pics and you can see how nice his drives come out after a pass or two.
Also, his recommendation of the Land pride RB 37 was exactly what I envisioned for your use.
