2006 New Holland TS115A
   / 2006 New Holland TS115A #1
USAF JAPAN
KADENA AB, JAPAN
A FEW DIFFERENT MODELS
We have a NH TS115A tractor that is barely moving when in any gear. RPM's increase to 2500 but tractor is going no where. Is there a way to adjust the clutch without tearing the transmission and cab apart? Synchronize the gears?
   / 2006 New Holland TS115A #5
if you let it get that bad clutch is probably shot, you can try to adjust it you don't have to split for that
   / 2006 New Holland TS115A #6
Hydraulic clutch. Have you tried changing the hydraulic filter? Also how cold? Ours would barely move last winter - normally it sits out the winter but we had to use it. It eventually got so it would travel faster and shift properly after it warmed up. I asked our dealer and he said to change the filter.
whis how do you adjust without the splitting? Can you send me procedures on how to? Thanks
MHarryE,
We first thing we did was change out the filter and flushed the system but no change...also was pretty warm here when it happened...also now vehicle intching forward or reverse when clutch is pressed and put in gear
   / 2006 New Holland TS115A #9
can't help on hydraulic clutch other than full of fluid and bled
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
Two Post Car Lift (A50120)
Two Post Car Lift...
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
