Adjusting side links for tilt with heavy implements
   / Adjusting side links for tilt with heavy implements #1
UncleBuck1
Baton Rouge, LA
2011 MF 2660HD; 1964 JD 4020 (may she rest in peace)
I need to clean up some roads (and I use that term loosely) on my property; I want to put some crown on them and maybe cut some light ditches on the sides and install water bars. I have an 8' box blade that weighs about 850# - other than going to a TnT, what is the easiest way to adjust side-link length to tilt something this heavy? Is there some trick to doing this that I'm missing?
   / Adjusting side links for tilt with heavy implements #2
I use a block of wood under one side of the implement to get slack in the turnbuckle. It will then move a turn or two. Then do it again. I can reach the lever and the turnbuckle at the same time so it is easy to tell when I have slack.
Bruce
   / Adjusting side links for tilt with heavy implements #3
I also use a block of wood but in the middle. Raise and lower the 3ph so the weight is off the attachment (slack in the turnbuckle).
Well that makes sense! I've been doing a block under one side like bcp, but unlike him I've never gotten two full turns before I had to adjust the list arms- more like 3/4 turn. Thanks!
   / Adjusting side links for tilt with heavy implements #5
I tried the center position once, but can't remember why I started using a side block. maybe sloping ground. Maybe old age. I probably ought to try it again sometime.
Bruce
6" & 8" I BEAMS UP TO 16' LONG (A51247)
6" & 8" I BEAMS UP...
2013 CATERPILLAR CT660L SBA 6X4 ROAD TRACTOR (A51247)
2013 CATERPILLAR...
2015 Dodge 5500 4X4 Bucket Truck (A53472)
2015 Dodge 5500...
American LaFrance Thermoplastic Striping Truck (A52377)
American LaFrance...
UNUSED 2022 MASTER TOW MODEL 7 CAR DOLLY (A51247)
UNUSED 2022 MASTER...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
