Dan707
I have zero tractor experience and just bought one (Ford 1910). It came with this Towner offset disc harrow. Has square bolts so its definitely got some age to it
First problem is, how does this thing go back together? It was taken apart for transit but my memory is failing me about how it went together
Second, is an implement like this something that gets attached to a drawbar or 3pt? Can you raise and lower it on the 3pt?
Finally, I was told that it would be a good idea to make some passes with this disc first on virgin ground, then go over that with the rototiller I also have. If the ground is soft enough though, could I just go with the rototiller alone?
