Shibaura SD 1643 starting trouble
   / Shibaura SD 1643 starting trouble #1
pohorsky
Loomis
to30, sd1643
We bought this little tractor about 10 years ago as a reman. Apparently the tractor is over 40 years old. Unfortunately the decal (SL1643) doesn't match to stamp on the block (SD 1643).:confused: Anyway I am guessing the stamp is more accurate. The other day when I was trying to start it after warming the glow plugs, it would putt once, then whirl or make a spinning sound. After playing with it for about five minutes it started and ran normal. I tried starting it later and it tried to do the same thing. I check to voltage - 12.7v. Any idea what might be wrong?
   / Shibaura SD 1643 starting trouble #2
Start with the starter. The solenoid may be worn and sticking.
Here is a pic of the starter. How would I go about testing the solenoid? When I listened again, it almost sounds like the starter is spinning, but not engaging the flywheel like it has a bad gear.
   / Shibaura SD 1643 starting trouble #4
The solenoid is the part with the label on it. You can test it by disconnecting the positive lead from the back of the solenoid that feeds the starter. Leave the smaller wires connected. Turn the key to start and you should hear the solenoid engage. Letting off the key the solenoid should snap back. If it does not remove it and inspect/ohm to determine if bad.
Another option is to remove the starter/solenoid as one unit and bench test it or take it to a shop for bench testing.
You can inspect the sprocket while the starter is out as well.
Okay. I pulled the wire going to the starter and no sound from the solenoid. Any need to test anything else or just get a new one?
   / Shibaura SD 1643 starting trouble #7
You can take it to any "Big Box Auto Parts Store" to get it checked for free.
   / Shibaura SD 1643 starting trouble #8
I would go ahead and get the starter tested as well. If you are handy you can rebuild the starter for a lot less than replacing.
As xtruckerbob stated, you can get it tested at the parts stores.
   / Shibaura SD 1643 starting trouble #9
if you can a rebuilder in your area most repair parts are available but keep this in mind you can get a new gear reduction starter for about $150.00 have sold many of these over the years cranks faster and quicker starts let me know if you need one can put you in touch with company that carries them
What is the difference between them and what I have now?
Thanks for the tips. I went ahead and pulled the starter and took it to Napa. The boy there said that he could only do a limited test and suggested that I take it up to Boyles Future Tech in Auburn, where they send stuff to be rebuilt. I'll do that tomorrow. Hopefully it all works out and it is just the solenoid.
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
SORKO MC19-10 LOT NUMBER 149 (A53084)
SORKO MC19-10 LOT...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
2014 FORD F-550 SUPER DUTY SERVICE TRUCK (A52472)
2014 FORD F-550...
