Tilt valve on Bob Cat will not work
   / Tilt valve on Bob Cat will not work #1
Lorcan
Ireland
Bob Cat S175
Hello
I bought a Bob Cat S175 (06) with 1500 hours. Its got all hand controls. Was working good. About 2 weeks age got into it and when you press the activate button on the left hand side all lights come on but the Tilt Valve light does not. On the left hand side the ACS light comes on. The hydraulics will not work. None of my local mechanics cannot help and my dealers in Ireland dont exist as far as i can see.Can anyone please help. A friend reckons its a solenoid on the ACS block. When I looked the is 3 solenoids i think took two apart looked ok. The third i cannot access. Also tried disconnecting the battery. There is also a problem code coming up 32-04. Can anyone please help. I really need this machine going in the farm yard.
Regards
Lorcan
   / Tilt valve on Bob Cat will not work #3
Code 32-04 is "No communication from ACS controller". Solenoids on the vavle do not affect this.
There are multiple reasons that could cause this. First thing to check is ALL fuses, fuse #10 & 12 both supply 12 volt power to the ACS controller.
Problem could also be loose connection at controller(s), broken wire in harness, actuator shorted out and this might cause internal failure of the ACS controller.
Hi checked the fuse and they seem to be ok. Now where is the actual controller situated and what does it look like. Also what are harness pins and plugs in the wiring. I f you could help me i would appreciate it.
Thanks Lorcan
black Max power washer (A53421)
black Max power...
2015 Ford F-750 Flatbed Truck (A55788)
2015 Ford F-750...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
Galvanized Livestock Gate (A55301)
Galvanized...
Toro 880 Procore (A55758)
Toro 880 Procore...
Giyi 59" Mini Stump Grinder (A53316)
Giyi 59" Mini...
