Your tire looks to be tubeless.
Are your tires filled with rimguard or WW antifreeze?
If not, the challenge is to break the bead so that a new valve assembly can be installed.
I will give you a suggestion assuming this is a rear wheel and that you have a FEL.
Remove the wheel and leave the tractor up on secure wood blocks. Place problem wheel where you can put down pressure on the edge of the tire near the rim.
You may need to put a block of wood on the tire for the FEL bucket to push down on. Hopefully this will break the bead and you can then reach inside to install a new valve assembly.
Alternatively, either take the wheel and tire to a tire repair shop or have them make a house call.
If your tire is loaded, it will be too heavy to move easily and you will need a tire repair guy to pump out the liquid and reinstall it.
Some tractors have a shield welded to the rim to protect the valve.
Don't ever weld on a rim with a tire installed on the rim.
A chemical reaction takes place leading to an explosion as shown in this video.
https://www.youtube.com/watch?v=HiLeji8bLOk
Dave
M7040
