JD 440 ID with 2-53 Detroit wont start
   / JD 440 ID with 2-53 Detroit wont start #1
rolandj
NJ
1960 JD 440 ID, 1999 John deere 445 lawn tractor w/ loader, 2004 Kubota bx 23
So about a month ago I started the machine and it started up I used it then parked it. I went to use it in recent snow storm and wouldn't start. Its like the throttle linkage is stuck closed because I gave it a shot of ether and it fired and idled a second but was like it was choked out. I sprayed all by the throttle linkage. I was reading something and almost seem as though something runs up and is controlled under vavle cover. I am wondering if something is hung up. I put heat on the tractor. it happened one time last year in the cold. I am confused.
   / JD 440 ID with 2-53 Detroit wont start #2
First plug in the block heater. The S series 2-53 used in the 435 and 440 was a dismal cold starter. When rebuilt with the N series piston and sleeve set along with C35 injectors . Starting is much improved .
It does would like a no fuel problem on your tracror . Is the fuel rack free to travel?
Worse yet if the engine does start and the rack is stuck. Zrrrrrrrrooooooommmmmm
I assume if I pull valve cover I would be able to see that.
2025 GIYI GY-X39F Hydraulic Trencher Skid Steer Attachment (A53421)
2025 GIYI GY-X39F...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
(4) PALLETS OF HEATERS (A55745)
(4) PALLETS OF...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2014 WHITE WATER CAMPER (A55745)
2014 WHITE WATER...
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
