Best Marker for Freehand Plasma Cutting
   / Best Marker for Freehand Plasma Cutting #21
I must have missed something here. You use wood as a guide for the plasma cutter??
Sure. If you need them to last a long time, glue some spacers on the bottom to hold the template off of the metal a little, and glue some aluminum foil to the edges.
You can also make a bushing that is the same outside diameter as your nozzle, with a hole in the center to allow a pencil point through. Use the bushing to trace a line arround the template, showing where the cut will be.
   / Best Marker for Freehand Plasma Cutting #22
Oh, yeah, I get that. For templates that you will use over and over? Yeah, I see that.
   / Best Marker for Freehand Plasma Cutting #24
You read it correctly.
My older HyperTherm 900 has a torch head diameter of 1.25".
That keeps the wood away from the cutting area by at least 1/2 that distance.
A Plasma Cutters has a more directed heating area, not like a Gas Torch, and if you are moving along the heat that reaches the wood is minimal.
I know wood and flame don't mix but if the flame isn't held there very long the wood will not ignite.
   / Best Marker for Freehand Plasma Cutting #25
I have a lot of wood templates and they last....I use 3/8 inch birch plywood. If i want them to last a long time (like circles) I coat them with sodium silicate which you can get at a pottery store. You have to allow for the offset of the torch head guide e.g. a 3" circle the template needs to be 4" in my case. Sure makes it easy to cut a hole and keep it clean.
   / Best Marker for Freehand Plasma Cutting #26
Oh yeah, I totally get it now. Just never had thought of that before.
I always say, "the only thing wrong with a Plasma Cutter is I didn't invent it". Rarely use my gas torch.
   / Best Marker for Freehand Plasma Cutting #27
I was going to say if you hadn't used one then you will not know but you have used one so IF. You need a clean hole, cut a piece of wood sized for othe hole and the offset of the cutting head (1/2 the diameter) and either clamp it to the piece or drill a center hole and bolt it on, then cut away.
Practice a little on scrap first to make sure you can hold the torch against the piece while running it around the outside or inside and have at it.
A circle can use either an outside or inside templet.
I use an aluminum bar for most straight cuts and clamp it on but the circles and patterns need a templet.
I have tried free handing the torch on some lines but for me it takes a l ot of clean up without the templet.
Anyway... It was a thought for an easy templet, rmully... thanks for the backup, sometimes you just need it on this sight.
2016 Chevrolet Tahoe SUV (A54815)
2016 Chevrolet...
72in Forklift Safety Basket (A56857)
72in Forklift...
2007 Ford E-350 Passenger Van (A55973)
2007 Ford E-350...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2013 Chrysler Town and Country (A56859)
2013 Chrysler Town...
