B7500 Loader "lift" and "dump" cylinders leaking
   / B7500 Loader "lift" and "dump" cylinders leaking #1
don716
Gold Member
North Georgia
Kubota/ B7500/with 2000 lb winch
My cylinders are leaking on my LA302 loader. Where can I get the rebuild kits for them? I cannot find anything online. Thanks.
   / B7500 Loader "lift" and "dump" cylinders leaking #2
Kubota dealer is a good place to start and get a price, then go from there.
   / B7500 Loader "lift" and "dump" cylinders leaking #3
Are the cyl leaking internally or externally?
It's not squirting out but it does drip out enough to run down my front tires. I thought just one was leaking but figured out all 4 was leaking so a rebuild is needed I think.
   / B7500 Loader "lift" and "dump" cylinders leaking #6
A shop that sells hoses and fittings may rebuild the cylinders for you. The chances are the cylinder will take generic parts.
   / B7500 Loader "lift" and "dump" cylinders leaking #7
Rod seal. ... May slow appreciably when the weather warms and give you a reprieve until winter next.
   / B7500 Loader "lift" and "dump" cylinders leaking #8
I used to rebuild my own - depending on the cylinder design it can range from easy to do to difficult. But then I got smart and started taking cylinders to a little hydraulic shop in a neighboring farm town. They seem to use a lot of generic parts - but the cylinders come back looking and working great for a reasonable price. They also make hoses for about half what the dealer charges.
It's not unusual for these little shops to not even advertise. Look to your local ag community - where there's a cluster of tractor dealerships there's likely to be a hydraulic shop somewhere nearby.
rScotty
JOHN DEERE 8245R LOT IDENTIFIER 263 (A53084)
JOHN DEERE 8245R...
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2024 JOHN DEERE 461M LOT IDENTIFIER 57 (A53084)
2024 JOHN DEERE...
