Buck Grab hooks, Slip hooks, Clevis mounts-what do use and where do you locate them?
   / Buck Grab hooks, Slip hooks, Clevis mounts-what do use and where do you locate them? #1
jodebg
New Hartford, CT
Kubota B-2650
I need to mount hooks on my bucket.
Looking for ideas on what to use and the where to mount them?
I'm sure that some great photos and information will be posted/thanks.
   / Buck Grab hooks, Slip hooks, Clevis mounts-what do use and where do you locate them? #2
I just welded two hooks off of the end of a chain. I placed them in line with the loader frame. Many ways to do it.
   / Buck Grab hooks, Slip hooks, Clevis mounts-what do use and where do you locate them? #3
I welded a 2"x2"x 3/16" angle to the top of my bucket for strength then welded 3/8" grab hooks to the angle. With the 3/8" grab hooks I can use 1/4", 5/16" or 3/8" chain. The hooks are welded inline with the loader arms. I also bolted 2 rope hooks (the chrome ones) on the bucket. Others have also welded a 2" receiver in the middle of the bucket to slide a hitch in for moving trailers around.
If you don't have a welder, another member here (Ken) sells bolt on hooks.
   / Buck Grab hooks, Slip hooks, Clevis mounts-what do use and where do you locate them? #4
5/16 grab hooks in line with the loader arms. The Kioti has little pads just in the right spot to weld them on.
IMG_20121117_170314_242.jpgIMG_20121117_165314_192.jpgIMG_20121117_164305_653.jpgIMG_20121117_162424_854.jpg
   / Buck Grab hooks, Slip hooks, Clevis mounts-what do use and where do you locate them? #5
Bolt-On Hooks
Advertises here.
Great products, easy to mount.
Ken is easy to talk to.
George-
Not familiar with rope hooks?
   / Buck Grab hooks, Slip hooks, Clevis mounts-what do use and where do you locate them? #7
If you search the term "hooks" you can read for hours, there are some great series posted by many different members here.
We can supply hooks for welding or bolting, and many rigging accessories as well.
71055 (A49346)
71055 (A49346)
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
71063 (A49346)
71063 (A49346)
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
