John Deere Model A
   / John Deere Model A #1
dieselman1967
McDonough, GA
1967 Ford 2000, 1951 John Deere Model A, 1974 Massey Ferguson 150 Diesel
Well I added this '51 Model A to the barn today. It's gonna need some carb work, as you have to have the choke out a little bit to keep her going, and the brakes are nonexistent...but all and all I'm quite satisfied! I'm sure I'll be back with questions as I go along!
   / John Deere Model A #2
If no brakes,it must have great compression to park on that cliff face! :)
I REALLY like their sound.
Bruce
Haha yea I don't know why the pic is like that. On my phone it is correct! Oh well
   / John Deere Model A #4
Needs carb work or just some tweaking of the settings?
The brakes are pretty simple and straight forward, IIRC.
Might have to have the brake shoes custom fit for pads.
A youtube video with good info.. in parts.
https://www.youtube.com/watch?v=7SoVmLm5MNA
I'm hoping it just needs some adjusting. Hopefully I'll be able to look at it tomorrow. And thanks for the link!
Well I'm in the process of changing the oil for the first time in who knows how long. The oil is the nastiest stuff I've ever seen...Just clumping out of the drain. And it looks like there is water in it, although the rad doesn't appear to be losing water (it is still full). I'm going to fill it back up with some sea foam and run it to try and get the rest of it out, then change it again. I'm starting to get nervous That it might be a head gasket. Time will tell though I guess
   / John Deere Model A #7
Sea foam?? I thought that was an additive to the fuel? Learn something new every day.. :)
If just cleaning out sludge in the engine oil, I'd use kerosene or fuel oil (diesel) and just flush it through without running the engine. Then when it looks like the sludge is flushed out, run some more through and run the engine a short while.
Then fill with good engine oil.
Plugs should help tell what is going on too.
May have been stored outside without a can over the exhaust and water got in that way.
But hope you find all is well in the end.
   / John Deere Model A #8
Might just be years of condensation.
Bruce
Well the "water" looks to be gas. I've read that it is somewhat normal for these things to mix a little fuel with the oil (correct me if I'm wrong). The sea foam definitely helped get some of the sludge out though. And she smokes a lot less than before. Still have a few leaks to fix around the petcocks underneath of it.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
