1965 Ford 2000 (3 cyl.) gasser. Coolant leak. Advice needed.
   / 1965 Ford 2000 (3 cyl.) gasser. Coolant leak. Advice needed. #11
. . . After some consideration I choose to replace the belt and both hoses which were still apparently in good shape, but whose risk of premature failure was not worth my time of tearing the cooling system apart again
Wise decision. You should be through with the cooling system for years to come. :thumbsup:
Here is a picture of the weep hole from the old pump. Is this incriminating enough? Is the stain from the coolant typical or is this an indicator of the failed shaft seal?
   / 1965 Ford 2000 (3 cyl.) gasser. Coolant leak. Advice needed. #13
If it was dribbling from there, a shaft seal was going, and if a seal goes, the bearing ain't far behind..
   / 1965 Ford 2000 (3 cyl.) gasser. Coolant leak. Advice needed. #14
I was just looking thru the photos and I see a issue with your throttle/governor linkage that will need to be repaired. There is a pivot pin that is lose in the housing that is allowing the lever to lay off to the side.
I tried to circle the issue in the photo.
   / 1965 Ford 2000 (3 cyl.) gasser. Coolant leak. Advice needed. #15
Ironically after reading this post last week I'm currently in the process replacing a water pump on the identical tractor.
This is what your linkage should look like
Winmac- Could you please post two more images of this linkage. One from a 45 degree angle (i.e. move 45 degrees to your left relative to this image) and one from a 90 degree angle to this image? The additional views would be most helpful to me and my explain why I have always wondered why the governor acts so sluggishly on my tractor. Thanks.
   / 1965 Ford 2000 (3 cyl.) gasser. Coolant leak. Advice needed. #17
Unfortunately the tractor is back together, 3hr start to finish, and that included hammering the sheet metal into something close to what it was.
   / 1965 Ford 2000 (3 cyl.) gasser. Coolant leak. Advice needed. #18
Here is the second problem area in the governor linkage, I had to machine bushings to repair this a few years ago. The arm pivots on the large bolt behind the spring.
The big issue with the linkage is the pivot points seize up, causing issues.
   / 1965 Ford 2000 (3 cyl.) gasser. Coolant leak. Advice needed. #19
tmac theres a rod that turns 90* and goes thru that linkage/arm thing. That 90* arm goes to the pivot bracket behind the spring in winmacs last pic. check all those for play/lost clips pins etc
   / 1965 Ford 2000 (3 cyl.) gasser. Coolant leak. Advice needed. #20
Make sure you get the green stuff cleaned up before a dog or cat gets a chance to get into it.Friend I worked with swore his neighbor killed his dog. With antifreeze. He had been working on his own van that weekend and drained the coolant.
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51691)
2014 International...
2017 Nissan Altima Sedan (A51694)
2017 Nissan Altima...
POWER BREEZER PORTABLE ELECTRIC EVAPORATIVE COOLER (A51248)
POWER BREEZER...
1269 (A50490)
1269 (A50490)
