Price Check Ford 2910 1998 model value?
   / Ford 2910 1998 model value? #1
sittinstill
griffin, ga
Massey Ferguson 1533
Trying to sale this for a friend. Has approx 600 hrs. Rear right break does not seem to work. But over all runs good. Not a beauty queen. Has one new rear tire and 2 fairly new front tires. Has a rear remote. Lift works great and holds .
what should I expect to be able to get out of it ?
Thanks for the help. I'm pretty sure it's 600 hrs, but I will double check today. Ive got my dad using it today to see what all it needs.(actually to see if hour meter works too) The guy bought it new and all he has ever done is deer food plots and a few odd jobs bushhogging, but it has always sat outside in the elements.
I think if the hours are correct, I'll change the fluids so I know it's been done, fix the head lights and see if I cant adjust the break. I'll see what I can get for it? Trying to get 7800 if possible.
Thanks
548 hours or 5484 hrs???
Please help
   / Ford 2910 1998 model value? #5
<img src="http://www.tractorbynet.com/forums/files/new-holland-buying-pricing/416932-ford-2910-1998-model-value-forumrunner_20150316_182246-png"/> 548 hours or 5484 hrs??? Please help
It's 548. Take some pics from all sides for us. Also take a side view of clutch pedal so we can see how much the knubs are wore down (overall height) on top of the pedals. This will tell me a lot as I've looked at and bought these tractors for many years now. Also the right rear tire looks to be original as this tire was obsoleted many many years ago. I believe they still make a 4 ply and 10 ply but figure that's either a 6 or 8 on that tractor.
Sent from my iPhone using TractorByNet
I appreciate help on this!
   / Ford 2910 1998 model value? #7
Definitely a low hour tractor. That being said it could have 548 or 2000 hours if the tach didn't work for a while etc. Either way it's low hours for that year model. The rear right tire is probably original but the left is definitely not original. The fronts "if OEM" will be either Armstrongs or Goodyears and should show signs of cracking from sun damage. Probably a 6.00x16" tire. In most cases these smaller tractors (with low hours) will have more clutch pedal wear like your picture than say a 5610 or 7610 due to being used in smaller fields etc. Like for Food plots etc sometimes they are very small which can require a lot of use on all the pedals. This tractor may look like **** but it may run like a new one too. If that's the case a paint job can turn it back to a prince. If it cranks fast and operates well you should easily get 7500 and potentially 8500 depending on your area.
Thanks for the help. It is not a beauty queen but fires on the first lick and runs like a champ. I think for now Ill slap it on the local list for 8000.00 just to see. At this time I don't have a lot of time to go threw it and paint it. To many irons in the fire!!! Thanks again for the help
Little pressure washing and rubbing and it will make someone a happy ride!
If I didn't have 2 running and 3 project tractors this would make another nice addition, but at some point I may run out of attachments to put Tractors on.
Thanks again!
Poly Bristle Sweep, 78" x 8" (A59076)
Poly Bristle...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
40' High Cube Multi-Door Container (A57149)
40' High Cube...
2166 (A58376)
2166 (A58376)
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
