Legend Attachments compact tractor grapple
   / Legend Attachments compact tractor grapple #1
Rotax
Saskatchewan Canada
IH B275
Just wondering if anyone had one? I am thinking about picking one up for my Bobcat S250, yes I know its small for my machine but I will only be using it for brush piles on the farm and also moving a few fallen trees around. I am sure it would work great for that, also they want $1000 dollars less for it than any other grapple I have seen for sale around here. Thanks everyone.
BTW the seller says he has used them on skid steers with out a problem, the hydraulic cylinders on the compact tractor grapple are the same as what they use on there skid steer grapple. So no worries about blowing a cylinder out.
   / Legend Attachments compact tractor grapple #2
Okay, their compact tractor grapple looks fine... although it only opens to under 36" - a sticking point for many here on TBN. But I don't see any prices. A comparable EA is under 2 grand, so if this is 1 grand it is worth snapping up.
edit: just noticed you are in Canada - trying to compare our prices seems to be apples and oranges.
Well, I went and picked it up yesterday and it seems very well built and think it should do the trick nicely. Only thing I don't like about it is it doesn't have any guards over the cylinders and thats something I might have to make up.
   / Legend Attachments compact tractor grapple #4
Did you pick it up locally or did you have to go across the border? I'm always curious do you have a 3rd function or did you just run lines from the rear? Thanks
Brent
   / Legend Attachments compact tractor grapple #5
I have a Gorilla Grapple without a guard. I bought it used just over 4 years ago, so far no damage to the cylinder or hoses.
Brent
I got it "locally" It was in the Regina SK area. I put it on my Bobcat that already has aux hydraulics.
   / Legend Attachments compact tractor grapple #7
Thanks,
brent
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
Lift Gate (A52377)
Lift Gate (A52377)
2005 CHALLENGER 500 BBL FRAC TANK (A53843)
2005 CHALLENGER...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
