Leak test a water hydrant/facuet ?
   / Leak test a water hydrant/facuet ? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Assuming my water hydrant for the horse barn ever thaws out, I suspect that part of the issue may be if the seal has a slight leak, with probably not the best drainage around the weep hole.
Other than pulling the hydrant and inspecting the gasket, even after I reassemble how can I be 100% sure there's not some leak through?
I'm thinking of installing a pressure gauge in the house basement that feeds the underground line, downstream of the basement shut-off valve. Will this work to do a leak test?
If I shut off the feeder valve in my basement and watch the pressure, if the hydrant valve is not leaking, how long will it hold the pressure? Or conversely, if there's a slow leak at the downstream faucet, how quickly will the pressure drop?
   / Leak test a water hydrant/facuet ? #2
Yes you can install a pressure gage. You can also listen to it when turning it on. If you crack the valve slow you can listen to hear water rushing past the valve if the hydrant has been off a couple days. If you Get a Gage get a gage close in scale to your pressure. Say if it's 90psi get a scale 0-100, this allows to more closely see pressure changes. If its a frost proof hydrant that stands up out of the ground you can typically rebuild them without digging them up. I am actually in the process of doing this to mine. If you need better drainage around the weep hole, there is no way around that. You have to dig it up and fix that.
I'm curious that if I do a pressure test, can I expect a good, non-leaking faucet to hold the pressure for an hour, hours, days?
   / Leak test a water hydrant/facuet ? #4
If it is a frost free and has a slight leak, I have had good luck with re-adjusting the travel of the rod. On mine it's a square head bolt. Shut it off, loosen the bolt, open the handle a bit, tighten the bolt and close again. You can usually hear the water flowing by putting your ear up to the hydrant.
(The only time re-adjusting did not work for me was on a hydrant at the bottom of a big elevation change, it simply picked up too much pressure for the hydrant to overcome. I ended up having to cap it off and move the hydrant else where.)
You can unscrew the top from the upright pipe and replace the rubber part if still doesn't work.
If you do need to dig it up due to poor drainage I have a few tricks for that too. Just let me know.
   / Leak test a water hydrant/facuet ? #5
Now come on if a good non-leaking faucet does not leak it will hold until it's bad and it leaks :D
but in all seriousness if it was mine and it was suspect I would start with the following.
-shut the hydrant line main down
-don't use for 24 -48 hours or more if possible
-SLOWLY reopen hydrant main and listen for an inrush of water.
-then let's talk gages
A good hydrant should not be bleeding down. I have two on a water line. One is an OLD meril maybe and I know it leaks out the weep when on, the other drips out the faucet when there is line pressure but the hydrant is off. The first i mentioned will not freeze because it's leak is down deep. The second freezes up because it leaks by up the hydrant line and probably doesn't have good weep drainage either.
Why would there be an inrush of water to hear?
With the main in the basement turned off, would any water drip past a leaky seal? For that to happen, wouldn't there have to be a way for air to get in?
   / Leak test a water hydrant/facuet ? #7
Say your line is 100 psi and you shut it off. If the pressure drops from the shut off to the hydrant to 50 psi, when you slowly crack that valve you will hear that water equalizing.
I'm working out of town this week but staying in our vacation home. We leave the water off when gone. Upon arrival I went in and flushed a toilet. That drops the pressure off the line, so when I turned it on at the meter I could hear that water moving to equalize pressure. I stand there for a bit to make sure it stops incase there is a broken pipe. Once I hear it stop, I know i have no sizable leaks.
Try it on your hydrant.
-Shut it off
-walk out and open hydrant briefly to bleed pressure
-walk back in and slowly open water line back up
Water is incompressible. Aren't you hearing the water refill your toilet tank?
   / Leak test a water hydrant/facuet ? #9
Yes, your right, but what I'm saying is if you shut the main off and bleed pressure off the hydrant, you will hear the line repressurize when you barely crack the valve. I am just giving you a SIMPLE, quick, and nearly effortless way to first check it out.
   / Leak test a water hydrant/facuet ? #10
If the hydrant is leaking with it shut off especially with pour drainage won't water be dripping from the top when it's off. That's how I discovered one of mine was leaking and had to adjust the rod.
2018 John Deere 325G (A47477)
2018 John Deere...
2014 Top Hat T/A 18FT Utility Trailer (A52377)
2014 Top Hat T/A...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
