BX2200 Valve clearance check
   / BX2200 Valve clearance check #1
Barneyhunts
Gold Member
Dimock, Pa.
Kubota L4240 Kubota B7800, Kubota BX2200
My BX2200 has nearly 800 hrs. on it. Maintenance requirement is for a valve clearance check and I wonder if it is worth doing. Has anyone done it? What did you find? I use my tractor for mowing and snow blowing and have not noticed any drop in performance so I wonder if this check is necessary.
Thanks,
Barney
   / BX2200 Valve clearance check #2
Hi Barney. I did my first valve adjustment at 1170hrs. I only needed a minor adjustment to bring them into the mid-range of the specs.
Not a difficult task. Worth taking the time to check. Engine did run smoother afterwards.
Thank you for your quick response.
Barney
Have you ever seen a video on how to do this?
   / BX2200 Valve clearance check #5
I think there is one on youtube. If you have the workshop manual it walks through the process.
Thanks, I do have the manual. I'm not sure how to turn the engine over or how to determine TDC.
Barney
   / BX2200 Valve clearance check #7
Did my BX24 about 2 years ago. NOT hard. Used WSM. Minor adjustments.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
