Anyone use Sinopec hydraulic oil?
/ Anyone use Sinopec hydraulic oil? #1
Rosch42
Central Maine
Landtrac 390HST
I, like everyone on here is always looking for a better price on good quality hydraulic fluid. I came across this ISO 46 hydraulic fluid from Sinopec for $350 a 55 gallon drum. The price alone is throwing up some red flags, so I want to know if anyone has ever used anything from Sinopec and what their opinion of it is. And yes I know it's made in China, so it probably has lead paint in it.
/ Anyone use Sinopec hydraulic oil? #2
Its your tractor, but I wouldnt do it.
You'd be lucky if all it had was lead in it.
/ Anyone use Sinopec hydraulic oil? #3
Actually, you can get 5 gallon jugs of Super S hydraulic oil at Rural King for $21.99 per gallon. That's cheaper per gallon. Guys around here use lots of it in everything from heavy equipment to log splitters with no issues.
Chris
Chris
It's amazing the price differences from region to region. It's ON SALE at my local TSC for close to $30 for 5 gallon bucket.
/ Anyone use Sinopec hydraulic oil? #5
That's a better deal still than the 55 gallon drum.
Chris
/ Anyone use Sinopec hydraulic oil? #6
I would not trust their oil at all. I have one of their tractors which is fine, but has had a few problems that were readily fixed. You can't do that once you have the oil in your machines.
I would stick to the main brands and even check out what Napa charges for their own brands for 55 drums. Even Walmart oil will probably be better than Sinopec stuff IMHO
/ Anyone use Sinopec hydraulic oil? #7
Noticed a discussion on Sinopec oil, I would like to help with questions or concerns. Our company supplies Sinopec lubricants and I help in the technical department.
Any big stores carry sinopec hydraulic oil in drums?
Sears.com
What is Sinopec oil?
Sinopec is the 2nd largest oil refiner in the world and the 4th largest lubricant company globally, ranked 3rd on the Global Fortune 500 companies for 2014.
Sinopec partners with some of the biggest
Shell, Sinopec and Total partner to build industry?s first shared Lube Park in Singapore - Shell Global
BP and Sinopec set up joint venture marine bunkering business | Press | BP Global
Sinopec to Join Chevron Gas Project - WSJ
ExxonMobil and Sinopec to develop gasoline technology
http://www.wsj.com/articles/SB10001424052970203550304577138493192325500
http://www.hydrocarbonprocessing.co...ed-technologies-for-methanol-to-gasoline.html
Sinopec in the US
Colorado: CNOOC gained a one-third stake in 800,000 acres in northeast Colorado and southwest Wyoming in a $1.27 billion pact with Chesapeake Energy Corporation.
Louisiana: Sinopec has a one-third interest in 265,000 acres in the Tuscaloosa Marine Shale after a broader $2.5 billion deal with Devon Energy.
Michigan: Sinopec gained a one-third interest in 350,000 acres in a larger $2.5 billion deal with Devon Energy.
Ohio: Sinopec acquired a one-third interest in 235,000 Utica Shale acres in a larger $2.5 billion deal.
Oklahoma: Sinopec has a one-third interest in 215,000 acres in a broader $2.5 billion Energy deal.
Texas: CNOOC acquired a one-third interest in Chesapeake Energy’s 600,000 acres in the Eagle Ford Shale in a $2.16-billion deal. Leased first oil rights in Texas bought a multi-million dollar stake in 600,000 acres of South Texas oil and gas fields.
Wyoming: CNOOC has a one-third stake in northeast Colorado and southeast Wyoming after a $1.27 billion pact with Chesapeake Energy. Sinopec gained a one-third interest in Devon Energy’s 320,000 acres as part of a larger $2.5 billion deal.
Sinopec Lubricants in Houston , Long Beach , Los Angeles , New York , New Orleans
http://english.sinolube.com/highlights/20120926/22438.shtml
Product Data Sheets and MSDS can be found at http://reddrums.com
/ Anyone use Sinopec hydraulic oil? #8
Why competitive oil prices at a time where crude oil is at an all time low? So bulk of the global oil production comes from large oilfields that are run and owned by the largest oil companies.
Sinopec Lubricants, founded in 2002, now one of the largest top grade lubricant manufacturers in the world. In 2014, production reached 521 million gallons from its 12 manufacturing super plants. The high level of Sinopec Lubricant Oil quality is based on rigorous selection of base oils and additives and continuous monitoring for all products.
Throughout the manufacturing process, each batch is subjected to numerous tests and controls designed to verify the highest quality of products. After stringent quality tests, finished products undergo a final meticulous examination by expert engineers to issue an authenticated certificate of analysis to verify performance results.
Sinopec Lubricants are ISO 9001, ISO/TSI6949, ISO 14001, OSHAS 18000 and AS 9100 certified, and blends to API/ACEA/DIN/HSE/JASO quality specifications.
The big guys..
Big Oil: Which Are The Top 10 Biggest Oil Companies? | OilPrice.com
/ Anyone use Sinopec hydraulic oil? #9
I have never heard of Sinopec oil but having read that it is Chinese owned is more than enough reason for me not to use their product regardless of the claimed quality.
/ Anyone use Sinopec hydraulic oil? #10
https://www.walmart.com/ip/AW-68-Hydraulic-Oil-Fluid-ISO-VG-68-SAE-20-55-Gallon-Drum/54045734
Sinopec Anti-wear Hydraulic Oil ISO VG 68 is a premium heavy weight paraffinic based hydraulic oil, ideal for industrial applications or for the hydraulic systems in warm weather regions. It is a rust and oxidation (R&O)-inhibited oil with the added benefit of an anti-wear additive package for protection. Approved for industrial applications requiring an ISO VG 68.
/ Anyone use Sinopec hydraulic oil? #11
[video]https://www.bloomberg.com/news/videos/2017-03-30/why-jpmorgan-s-scott-darling-likes-sinopec-video[/video]
/ Anyone use Sinopec hydraulic oil? #12
/ Anyone use Sinopec hydraulic oil? #13
/ Anyone use Sinopec hydraulic oil? #14
OK you got your free ads.
We are almost two pages in, does anyone here own a tractor that specs AW32, AW46 or AW 68 oil?
Does everyone understand the difference between UTF and AW oils?
/ Anyone use Sinopec hydraulic oil? #15
I have seen there name in places, have never used there products.
I have wondered about the name as it is very similar to a manufacture of really good lubricants,
Cen-Pe-Co is good lubes, don't know about Sinopec.
/ Anyone use Sinopec hydraulic oil? #16
Hello, I have worked in the oil industry for 34 years 27 of which was in a refinery where for a number of years we blended and packaged oils and greases under our own and hundreds of brand names. When it comes to hydraulic oils the money is in the additives and that's where the cheaper oils skimp. The anti wear and oxidation resistant additives are expensive. A good way of telling any oils quality when it comes to the base oils used is the viscosity index which is how the oil holds its viscosity over varying temperatures. You have to compare only exact type and weight oils to use this method, you cannot compare a 5W30 with a 5W20 or a 10W40 as their VI's are different. On hydraulic oils the Oxidation Stability test (ASTM D943) will give you a good indication of the quality of the additive package. The lower quality products sometimes don't even tell you what this number is. It's rated in hours and can range from 2000 hours to 5000 hours. Ask what the result is especially if it's not advertised and use this as a tool to make your choice. I sell 2000 hour oil that people mostly use in things that leak a lot and I also have Kendall oil in drums that has a 5000+ hour rating. Hope this helps and have a Wonderful Day!
/ Anyone use Sinopec hydraulic oil? #17
What is the ASTM D943 test result on the above oils? Thanks!
/ Anyone use Sinopec hydraulic oil? #18
I've used the 10w30 gl4 universal tractor brake hydraulic fluid and it was great stuff ,functioned as good or better than the Mahindra fluid the Sinopec apparently gave my tractor more hydraulic power while operating fel lifted both rear tired off the ground flat footed Mahindra brand never did that. Sinopec also didn't cause brake chatter or break down in high heat or long operating times but I changed back to Mahindra brand for possible warranty concerns, they have dye in their fluid and test it if an issue with the trans occures. Sinopec is a fine quality fluid don't know about their other product oil types.
/ Anyone use Sinopec hydraulic oil? #19
Just think...all the money you save buying Communist oil can go towards building a Mexican wall to keep cheap labour out of your country. Then you can hire Chinese Temporary Foreign Workers to do your labour because you can't find citizens willing to work for sub-living wages. I bet you there is a government subsidy out there to help out with your TFW program. Win-Win.
I'm willing to bet that the majority of these "New Member" posts in this thread all have IP's from either mother China or through some VPN originating in China.
/ Anyone use Sinopec hydraulic oil? #20
yep you sure stated a lot of truth there but fact are, just as well put China oil / fluid in that china/ Korea / Japan / India made tractors. For the most part Americans don't have a choice that could make a big difference due to the facts our government has for years outsourced just about everything to other countries from auto / tractor / catfish / chicken / crayfish / you get the idea. My ip is not from China nor do I have an desire to push others countries products. I hope this forum is not like some churches where the old timers have been there so long they claim ownership and don't want to hear what youngsters beliefs are, of course I don't consider sixty as young. Just saying I can try and help someone out from time to time or find something else to do on my farm. Worse hydraulic fluid I've used was a Shell product two best Sinopec & Mahindra, so far.
