Adjusting clutch on Case Int 485
   / Adjusting clutch on Case Int 485 #1
9er
Douglasville, Georgia
Case International 485
It's probably ( hopefully) a simple one, man job; but how can I adjust he clutch on the CI 485. It was/is my Pa-n-laws but he has progressed with Alzheimers and I now take care of his 28 acres. I noticed last week after days of bush hogging and plowing that it is WAY to high. It won't release til right at the top. Any help/advise links appreciated.
9er
Jeff
   / Adjusting clutch on Case Int 485 #2
Here is the page from the manual:
   / Adjusting clutch on Case Int 485 #3
It's an easy "fix" since all you are doing is adjusting the clutch pedal height. The posted diagram is the best help you can have. The actual clutch is self adjusting.
   / Adjusting clutch on Case Int 485 #4
They came with a throw out bearing that was designed for the release fork to ride on the bearing all the time. I didn't like that, so I made a stop on the clutch arm and put a return spring on it.
Thanks for the info. Be blessed.
9er
Jeff
Thank you so much GeneP. That was exactly what I needed. Looks like Monday I should be able yo get that adjusted. You have a blessed Sunday.
9er
Jeff
2012 Ram 4500 Chassis Vesralift Bucket Truck (A50323)
2012 Ram 4500...
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
Krone Swadro 46T (A50120)
Krone Swadro 46T...
Vermeer 840 Discbine (A50774)
Vermeer 840...
