A couple of time saving tricks I came up with , or i think i did
   / A couple of time saving tricks I came up with , or i think i did #11
My neighbor tumbles his parts, bolts, ext in a mixer and black beauty blasting "sand".
   / A couple of time saving tricks I came up with , or i think i did #12
For bolts I would instead dip in Kroil and run a cheap [purposed] hex die on them. Blo off and apply Chain Wax to store. McMaster Carr has cleanup/close quarter dies for less than $2 ea
   / A couple of time saving tricks I came up with , or i think i did #13
I have posted this before someplace but years back I had a gas tank from a Honda motor that was all gummed up inside with old gas. It had some bolt mounting holes on it and I attached some flat bar to it and then tacked the flat bar to the mouth of the mixer. Added some sand and gravel from the drive way along with some type of cleaning fluid and spun it around for a few hours. After I cleaned
it out it was like new inside.
Al
I have found the more sand u put in the more it will balance out, but too much and it wont work properly it has to move around
Al
good idea, I had a truck tank that was full of rust, I threw every piece of brass I could find in it and shook it around, I used brass to prevent sparks, I also attached an old electric sander I had to it for vibration, then rotated about every hour, it did a pretty good job of cleaning it out. I know there are solutions for this but once again I live in the boonies, lol. It did solve my rust problem for the most part. I thought of sand, but I didn't want to clog my system even more.
Thanks for the tip
Rob
I have hundreds of pounds of bolts lol, I would be there forever with a die.
Im not sure what chain wax is, where do u get it
thanks rob
   / A couple of time saving tricks I came up with , or i think i did #17
We have a sail boat in salt water so tools rust. To save tools like pliers, I put them in Vinegar, or another mild Acid like Coka Cola.
   / A couple of time saving tricks I came up with , or i think i did #18
thanks rob
Chain Wax is directly available at motorcycle dealer stores. Best deals on the internet if you decide to buy a few cans at a time.
... Gotcha re the bolt quantity. I just like to keep as much of the threadform as possible so a quick [Kroil soaked] on/off zip with an impact gun on a hex cleanup die would be my method.
"I also use a die, but only If I have bad threads. Im not sure what the term "threadform " means, I have never heard that b4.I have a huge supply of organized like nuts bolts etc. My dad had me sorting nuts and bolts from the time I can remember , he had a professional repair shop. I was always out there from the time I could walk, Im sure he had me sorting to keep me out of his hair, lol. Over the last 40 years I have kept up this habit , mainly when I need to veg out I sort nuts and bolts , I have a huge assortment of sorted nuts and bolts by from 6/32 on up. I will say I can look at pretty much any nut or bolt and tell you the size , thread pattern, and pretty consistently I can even tell you if its metric or not in about a second lol.
   / A couple of time saving tricks I came up with , or i think i did #20
Yeah, I save em and keep em sorted too. The thread form is the form of the threads, changed little by rust, but more by grinding it off by tumbling. Also the inherent bolt thread collisions. Hence I prefer to wire brush then shave remanent rust off with a die. The die doesnt stay very sharp due to abrasive nature of rust, but the die serves its cleanup purpose durably. I also stock an assortment of Gr5 bolts and Gr8 washers bought new by the pound from TSC for the more exacting needs I run into on equipment for the farm.
larry
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
John Deere 920 Platform (A50514)
John Deere 920...
