Want to put up a shop..
   / Want to put up a shop.. #11
Around here prices vary depending on quality. Morton building is top of the line and cost (in 2012) about $27/sqft, 36 x 75 ft, 12ft ceiling, insulated R19, rib sheet metal inside and out, two 4 X 4 windows, two man doors, one 12 X 12 roll up door, plumbing for toiled connected to septic, water line installed, reinforced concrete floor with 18 X 25 ft apron outside. $74000.
Morton Buildings
   / Want to put up a shop.. #12
My old farm shop is a home built steel building 30x30. We cut and welded the frame, bought the metal from a local supplier, poured the floor (8'') all ourselves. $12k.
My new farm shop is a 40x40x16 red iron steel building. 3, 14' rollup doors, 6'' concrete floor with footers and all the electric power I will ever need $65k.
Insulation is a must and well worth the extra money to me. I used the bubble style in the old shop and I would not recommend it. The new shop has 6'' fiberglass with is much better, but I would recommend spray foam. At some point, I going to spray foam both of them.
The same here in Ontario, ridiculous quotes. I was looking for quotes to build a pole barn 32x40 and the range was between 30K to 45K so I decide to build myself this year. You mentioned about laminated poles; where did you find that? I check around here and not available in Canada.
I'm not sure if laminated is the right term for the posts but they are 3 or 4 dimensional lumber boards(2x6, 2x8) pressed together to make the posts. Each one is treated PWF for in ground use. I just got another quote for a fabric cover building from the show, $20,000 for a 30x40 and it says purchaser to supply large skid steer. I can get twice the size in a pole shed with a 14x14 insulated door for $38,800. I wouldn't be surprised if a same size pole shed from this builder was the same as the fabric building. Now I'm trying to decide if I should go with a bigger building like the 60 x 40? I'll have to talk to them and check their price on smaller sizes. I hope there wasn't a typo on their estimate sheet for the 60x40. The bolt together buildings don't have anything to stop condensation and I think still need a foundation.
I'm thinking if I can get payments around $500/month over 5 or 6 years having a better building will be worth it in the long run. I'm also wondering about resale down the road. I read somewhere that you only get $.50 on the dollar on resale of a farm type building but I think it would add greatly having it on the land for the next owner. I'm tired of paying stupid ridiculous storage fee's($325 for a 10x15) and having nowhere to store my equipment or work on it. For a couple hundred bucks more a month it seems like a no brainer to me. I'll also have to check with the county and see about taxes and building permits and such.
   / Want to put up a shop.. #14
Morton Buildings
<snip>
Those prices just make me angry about appraisers.
I've 4 shops that cover 5,500 sq feet, all on thick concrete pad, no a/c but the two on the right had gas heat (until someone stole my LPG tank last year)
419395d1428038989-want-put-up-shop-outside-shops-jpg
The red one is 40' wide, 60' deep, 12' high with a 1 bedroom apartment 15' deep across the back, w/ shower, toilet, kitchen and this does a/c sink etc.
They are all wired and well lit, w/ 400 amp service (including about 8 240V circuits).
The appraiser never even went to the shops and placed the value of the shops at about $8,000 (that works out to $1.45/sq foot).
I've also a typical metal carport near the house that has a brick "floor" and only 1 side closed in. It's 600 sq foot, has 2 fluorescent lights and he valued that a $15/sq foot, or $9,000. It's the top pic
attachment.php
That's about the cost of a new one.
If that LAME appraiser had valued the shops and apartment at $15/sq ft it would have added about $70K to the appraisal, and made the loan REAL easy to get.
So Arc weld, don't count on the appraiser adding value for ANYTHING you do. They can be blind.
   / Want to put up a shop.. #15
It is the same here. Year after the shop building was built we added a heated/AC guest room and office 12 ft deep on the north side of the building increasing total cost to about 100K. When getting appraisal for refinancing it added virtual $0 to value of our property. The good thing is that our property tax didn't increase. In fact our tax decreased due to general drop of property values.
   / Want to put up a shop.. #16
I just got a quote on a 30 x 32 package deal 10' ceiling, 1 entry door and a 10 or 12 sliding door for a little over 9000. I think it even has the screws etc. In it. It is a pole building with metal roof and siding.
   / Want to put up a shop.. #17
My 30 x 48' x 12' "kit" cost around $10K with 1 entry door, without overhead doors, and my assembly. I added 3 overhead garage doors, and later the concrete floor.
   / Want to put up a shop.. #18
Hey buckeye, how much did it cost to add the concrete? I have a 30x40 shop with a dirt floor and I desperatly want to have a concrete floor! If I had the money, I would keep the 30x40 shop dirt floor and use as a barn and tractor storage, then build a seperate shop of modest size. But for now I think it would be cheaper to just add a concrete floor to the barn.
   / Want to put up a shop.. #19
Hey buckeye, how much did it cost to add the concrete? I have a 30x40 shop with a dirt floor and I desperatly want to have a concrete floor! If I had the money, I would keep the 30x40 shop dirt floor and use as a bar and tractor storage, and build a seperate shop of modest size. But for now I think it would be cheer to just add a concrete floor to the barn.
FWIW 8 yrs ago I had a 24x40 shop built and adding the concrete floor added 5k to the price in rural SW Virginia
   / Want to put up a shop.. #20
$25/sq ft sounds really high for a basic pole barn.
I am in the middle of building my shop, but had gotten quotes about 6 months ago. Was quoting 40x64x12, left open on one of the 40' ends for me to finish, and (2) 12' sliders on the sides. I had material roughly figured at 11-12k. Quotes were around 18k. I imagine if I had them finish the front maybe a few grand more. But I would guess still under $10/sq ft.
Prices must just be really high up your way.
As it is now, I am building my own. Went a tad bigger, 40x72. And decided to do a 6 course block foundation with a 12' wall on top of that. Gonna have 2 12' sliders, 1 18' overhead door. There will be a wall in the middle dividing it into a 40x40 section and a 40x32 section. The 40x32 will be gravel floor and not much else. The 40x40 will be insulated, concreted, finished with OSB walls and metal ceiling, electric, etc. I am anticipating a total material cost around 25k. And that includes several loads of gravel for the drive and for the inside under the concrete, fill, and floor for the unfinished side
Two Post Car Lift (A50120)
Two Post Car Lift...
UNUSED WOLVERINE SP-15-84W SNOW PUSHER (A54757)
UNUSED WOLVERINE...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
City of Lakeland (A51691)
City of Lakeland...
