Disc Harrow Dirt Dog or Everything Attachments or ... disc?
   / Dirt Dog or Everything Attachments or ... disc? #11
Yeah, that might help. On my first pass I had the side link in float so it dug too much on one side as the ground was sloped.
It could be I pulled my rear gangs out too far or maybe I had it angled too much.
Need to spend more time with it.
Very impressive to get that much till with 1 pass with a disc. Very nice. More picture please.
   / Dirt Dog or Everything Attachments or ... disc? #12
How about comment on ETA's screw adjustment of gang angles?
   / Dirt Dog or Everything Attachments or ... disc? #13
I haven't changed them much so i can't give a full review. I did take the rear gangs from no angle to max and as it got to no angle it was 1 finger turn at max you had to put maybe 3-4lbs of force. That may get easier as its worked more or harder with dirt and grime buildup. Time will tell.
As you could imagine, with all those threads from min to max, it took quite a few screws to go full range of motion but it is truly infinitly adjustable.
   / Dirt Dog or Everything Attachments or ... disc? #14
Thinking about it over coffee (could be dangerous). The cats meow may be to put a nut on the end then I can adjust with the push of a button with my cordless Impact wrench. 👍
Those battery powered impacts sure are nice. If the threads are dirty though, you might gall them if the impact over powers the dirt binding on the threads.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
1997 Freightliner FL60 Truck, VIN # 1FV3GJBC6VH725847 (A51572)
1997 Freightliner...
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
