Creating my horse barn
   / Creating my horse barn
I went with James Hardie lap siding for the exterior and trim.
Eddie
The interior walls of each stall are 3/4 inch plywood
Eddie
Yesterday I sprayed primer and paint on the inside of the stalls. A friend told me that horses will pee on the walls and I needed to protect them. I didn't know this, or even think about it, so I caulked all the seams first, then painted them to help protect them from soaking up the pee.
It's raining today, so I can't finish painting the trim. Once that's done I can put on the edge flashing for the roof and the gutters.
Eddie
The fence has been done for awhile, but it's not perfectly flat. Some holes are deeper then others and from a distance looks pretty bad. It's a simple matter of pulling the posts up and filling the inside of the post with a couple scoops of readi mix concrete from a coffee can and some water. Once it cures, the post is locked into that height. Karen's son Chad came over with a friend and spent the day doing this for us while I was working on siding.
Eddie
   / Creating my horse barn #66
Eddie
Eddie horse don't pee on the walls. you may have some splash if there is no bedding, but with straw or shavings no splashing at all. You should consider instead if the paint could be toxic to horses
I used exterior grade latex paint, so that should be safe if anything eats it.
After I was told about horses peeing on the walls of the stalls, I did some searching online and there are quite a few products out there to deal with it. I'm assuming it's the female horses who do this. And I'm also guessing that it's just some of them. My thought is to be safe then have to deal with it after it happens. Sealing the wood and putting some paint on it wasn't very hard or time consuming.
Eddie
   / Creating my horse barn #68
Eddie, 2,000v isn't bad at all, you could grab it bare handed and hold it. I freak out it mine drops below 6.5-7k.
   / Creating my horse barn #69
Around here most use either full 2x material or concrete knee walls in the commercial barns about 4 to 5' tall...
   / Creating my horse barn #70
We have the 3/4 plywood on out four stalls. Over the last 13 years, my has had 3-4 mares and so far we have not had an issue with the plywood rotting out.
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
STORAGE FEES (A54313)
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
