I dont understand my PTO and how it is supposed to work...
   / I dont understand my PTO and how it is supposed to work... #11
The big question is, how long will the pto take the pounding of a baler??? The pto drive line in many compacts isn't built to take that kind of pounding...
SR
The only time a small square baler pounds is when you feed it to maximum capacity.
   / I dont understand my PTO and how it is supposed to work... #12
As for engaging the pto, I agree with using just enough rpm to keep from stalling the tractor and engage the pto...
As for the pto brake, idle the tractor down before shutting the pto off..
SR
That's definitely the way to go...engagement of the PTO is a bit of a shock load...disengagement is too, but less so. Lower RPM reduces the shock load and will also extend the life of the PTO brake.
I don't know anything about balers, so I don't know how accurate Rob's first comment is...but those 4xxx series Deeres are pretty tough machines.
   / I dont understand my PTO and how it is supposed to work... #13
A non issue and don't worry about it. Just don't redline the engine and yank the pto into operation. Also don't have the engine running so slow that it shudders as the pto engages.
I agree. We run a baler with our Kubota L3830 and it has been fine so far. Just start at a low engine speed (just high enough to handle starting to spin it up without lugging) and idle down before you shut it off.
Aaron Z
   / I dont understand my PTO and how it is supposed to work... #14
To get back to how it works, your switch turns on a valve that provides hydraulic pressure to a clutch pack which engages the PTO. so it is not "direct drive". I in the manual, or in at least mine for a 4310, they ask you to engage the pto at idle, and rev the engine up to pto speed. same with disengaging it. idle the engine down, and then cut off the pto. The pto will spin for a little bit, but then stop. with the engine off, you should only be able to turn the pto 180 degrees before it stops. this is the "brake" they are talking about.
Ok thanks that is helpful and makes sense, but the operator manual does say to run her up to 2700/540pto and hit the switch, which seems stupid unless its hard on the engine otherwise. On my other tractor i can just feather the clutch to get it all going. So, I take it the clutch is going to slip somewhat to get it going, and somewhat to get it stopped. Here is what i am trying to get: With the pto engaged, at 540rpm, if i pull back on the power down to idle, then the pto will just freewheel and wind down, but when i disengage the pto, thats when the brake comes into play? When you say the PTO will "spin for a little bit" does that mean 10 seconds or so while the brake gently slows it down, or is it more like a just a few revolutions? I will have to post an emergency shut down procedure on the dash! :O) I generally feel blessed every time the old baler throws another out, and really dont want to experiment on it. thanks for all the help.
   / I dont understand my PTO and how it is supposed to work... #16
Relax. You are worrying yourself into a dither over nothing. Just rev the engine enough that the pto driveline does not shudder when the pto is engaged. If it's a small square baler the pto can be shut off at any rpm. if there is a high inertia pto load such as a generator or rotary cutter. Idle the engine back to lowest rpms then disengage the pto.
Ok I am starting to Relax. Part of this is just trying to get a definitive explanation on how it works, but i think i am there, thanks for the help.
   / I dont understand my PTO and how it is supposed to work... #18
New Holland balers already have an overrunning clutch built into the pto drive line. It's right next to the flywheel. Your tractor will have no problems running the baler
If yours does, you can turn off the PTO at any rpm without any effect on the tractor.
It's hard to imagine a tractor that can brake (break!) a high inertia load on the PTO. Seems like it would create a tremendous amount of heat somewhere.
   / I dont understand my PTO and how it is supposed to work... #19
I don't believe the PTO brake is really meant to quickly stop high inertia loads.
PTO brakes are used mostly on independent PTO models. Oil film between the disc's in the PTO clutch can cause the PTO to slowly turn when in the off position.
The PTO brakes keeps the PTO from turning when off.
I really dont know if my 1971 NH 277 Bales has an overrunning clutch built in-I have spun that flywheel both directions by hand many a time and dont recall that it does, it does however have shear pins. I to have doubts about any kind of brake on a "high inertia load" and the comments about idling it down and then turing the pto off are good, but that baler will spin for a long time to wind down (good bearings i hope, and same with brush hog), so the prospect of waiting around in certain situations for this stuff to wind down before turning off PTO is a little goofy. I think its just time for experimenting. I dont think deere would build anything that would be an issue like this.
2022 Caterpillar 300.9D Mini Excavator (A55973)
2022 Caterpillar...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
Auger Drill Bit (A56857)
Auger Drill Bit...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2014 PETERBILT 388 (A58214)
2014 PETERBILT 388...
