Adding a Gun Mount
   / Adding a Gun Mount #1
WPSmolder
Charleston, West Virginia
Mahindra 4025 4WD & Ford 8N
Hey guys,
I'm looking for advice on adding some sort of gun mount to a tractor. I'm not set on which type of firearm (handgun or long gun), but I'm wanting to add something that enables me to have a weapon within easy access without being obstructing. I have some remote sections of my property and wearing a holster isn't always the best option when working on the farm. If you've added some sort of mount or have thought about doing it, I'd love to get any suggestions or pictures you may have. Thanks!
-Patrick
   / Adding a Gun Mount #2
have a cab tractor that i keep a 22 rifle in. put my mounts behind the seat. out of the way and easy to get to.
   / Adding a Gun Mount #3
Put a saddle scabbard on the ROPS and shove in a lever 30-30.
   / Adding a Gun Mount #4
Do you have a canopy or cab roof? If yes then one of those over the visor racks they make for pic up trucks could be mounted up on the right side in reach but out of the way.
   / Adding a Gun Mount #5
For a long gun, an ATV scabbard with cover would work well and keep dust/debris off the weapon.
   / Adding a Gun Mount #6
I carry my KelTec PF9 in front pocket of any pants I have....it goes invisible....and I NEVER have it get in the way of anything I do...and that's a lot of positions and work situations.
It goes with ME...not stuck in a vehicle.
PF-9 | Pistols | Kel-tec
Works for me. Lightest, smallest 9mm available, period. Uncle Mike's pocket holster keeps it safe.
   / Adding a Gun Mount #7
Wow, you must be a good shot, I can't hit a barn with those little 9's although I do own an LC9. I carry my Beretta 92 in a shoulder holster and the fact that it hooks to my belt,, it also helps keep my pants up.
   / Adding a Gun Mount #8
Learning how to hit with a pistol, even a subcompact is a matter of practice.
Step 1, get a reloading press, the proper components, and learn metallic cartridge reloading.
Step 2. Go buy a few boxes of cheap Winchester, Remington or Federal FMJ rounds.
Step 3. After practicing with the commercial stuff, pickup and save the brass for reloading
Step 4. Reload, Practice, reload...rinse and repeat. Plan on shooting 10,000 or more per year.
You will get better. You just have to want it.
   / Adding a Gun Mount #9
I agree with you a hundred percent, and would be happy to discuss this further on a gun forum, but if you have ever held a PF9 or LC9 then you know the barrel is only 1 3/4 inches and not enough to carry the projectile with any accuracy at a distance. They are made for up close concealed situations. Anything running around here in the fields I don't want to get that close to
   / Adding a Gun Mount #10
Would something like this suffice?
Utility Trailer (A50860)
Utility Trailer...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
Super Material Lift MH1000 (A51039)
Super Material...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
19009 (A48082)
19009 (A48082)
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
