2005 GT2254 carb linkage for 22 hp B&S motor
   / 2005 GT2254 carb linkage for 22 hp B&S motor #1
clovergamecock
Gold Member
Clover SC
Kubota L2800 4WD FEL
I don't know if something fell off or is bent but the engine now runs either wide open or barely idling. The adjustment screw has no affect and the arm at the bottom of the carb bounces. Any ideas or pics of the assembly? Choke works fine and the throttle cable is in the same setting it has always been.
Thanks
Wade
Looks like the Engine is a Briggs, Model No. 40H777
   / 2005 GT2254 carb linkage for 22 hp B&S motor #3
From what you have described, I'm guessing, and I could be wrong, it's a governor related issue.
Here is another thread that discusses a governor issue on a B&S 20 HP intek engine, not exactly the same engine that you have but very close.
There seems to be similar issues to what you described.
There are some photos, that may at least give you an indication if something is missing or not, maybe it will help.
http://www.mytractorforum.com/12-john-deere-forum/203373-scotts-rider-problem.html
Great info! I will try this today. Thank your for sharing.
Wade
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A53843)
2017 GRAND DESIGN...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
