So confused-2620 or 2650
   / So confused-2620 or 2650 #11
how much stronger is the LA434 FEL on the B2x01 vs the LA364 on the B2x20? Its curious because you can put a SSQA on the 2x20, but most people discourage it because of the added weight of the bracket and how much that cuts down on your lifting capabilities.
Well as I have understood it (this might be wrong) SSQA is an option on the LA434, which to me means the loader specs do not include having that big heavy SSQA bracket on there and they look almost identical to the 364. So it should be equally hurt by the weight right? What am I missing?
LA364:
https://www.kubota.com/product/B2320/pdf/B20 Series Competitive Optional Implement Comparison.pdf
LA434:
http://www.kubota.ca/en/images/db/brochures/016855.pdf
   / So confused-2620 or 2650 #12
I agree with Tompet with other then the emmisions part as it is under 30 horsepower it does not require a regen system. The 50 series is a bit bigger then the 20' series so if size matters it might be a disadvantage.
Sizes matters, the 2650 can be a real advantage if you have some work to do.
   / So confused-2620 or 2650 #13
how much stronger is the LA434 FEL on the B2x01 vs the LA364 on the B2x20?]
Looks to me like the LA364 (B20) and LA434 (B01) loaders are nearly identical in lifting capacity from looking at the brochures. I suspect you are correct, that the quick attach bracket is not included in the rating for the LA434.
The LA534 on the B50 series has ~25% more capacity.
TYN T654 TRACTOR (A51243)
TYN T654 TRACTOR...
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52128)
2016 KBH...
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
Cattle Chute (A50515)
2007 CAT 904B (A47384)
