Ice maker use from freezer on fridge bottom topic
   / Ice maker use from freezer on fridge bottom topic #1
buickanddeere
Super Member
East Coast of Lake Huron
Deere, several
It appears that some households use a lot of ice ??? Is it a regional or cultural custom ? We have never had an ice maker since 1941 when power was connected to the farm.the only ice maker that we have ever used is a pair of one dozen cube trays in the freezer section. Unless making home made ice cream , then we just freeze a few old yogurt tubs ice ice .
   / Ice maker use from freezer on fridge bottom topic #2
The ice cubes in my freezer dry up and get freezer burn mostly. ;-)
They taste bad when they get that way. We always toss out the old ice and put in a couple of fresh filled trays before inviting guests over when ice might be wanted.
   / Ice maker use from freezer on fridge bottom topic #3
In Texas almost every drink has ice except beer and it's served best very cold. Iced tea year round.
I use the ice from the ice maker all the time. In the summer I fill up a ice chest with ice when we go to the store so the veggies won't cook if we make a second stop.
In the past, cheese at the top of the ice chest would melt.
   / Ice maker use from freezer on fridge bottom topic #4
I use a lot of ice in a cooler in the summer and found it's easier to buy freezer storage containers (about 1 qt. size) and fill with water and freeze.
They come out of the container easily can be used over and over.
I chip them with an ice pick.
Around here store bought ice is kept about 31.9 degrees in the merchandisers and melts very fast!
My 0* ice some will still be in the cooler at the end of the day!
   / Ice maker use from freezer on fridge bottom topic #5
We rarely use ice cubes- just let the water run cold from the tap. Once in a while I might use a cube or two - but they are a pain to bother with- so I don't. Soda or juice just sits in the fridge until it's gone. -regional thing.
   / Ice maker use from freezer on fridge bottom topic #6
I've never had the cheese melt, but all the rest of this post is just what we do.:laughing:
I'm old enough to remember when we had the metal ice trays with a lever you pulled up to break the ice cubes loose from the tray. The plastic trays that you twisted to loosen the cubes was a step up, but now I'd hate to have a refrigerator without an ice maker.
My wife drinks coffee all day, but doesn't want it hot. If it's fresh, she's going to put an ice cube in it. I drink 3 or 4 cups of fresh coffee when I get up in the morning, but then I keep a glass of ice water handy the rest of the day.
   / Ice maker use from freezer on fridge bottom topic #7
No ice cubes used here. Anytime we do decide to make them in the freezer we forget about them and then they shrink and taste disgusting and just take up room.
   / Ice maker use from freezer on fridge bottom topic #8
Try making ice using distilled water.
If you're like me, you'll never want any other.
It even looks better!
   / Ice maker use from freezer on fridge bottom topic #9
I don't want an icemaker in the freezer; too much possibility of a leak and resultant damage.
Same reason I want the clothes washer in the basement (assuming I have a basement.) Minimal damage if it leaks.
Plus, if I need a lot of ice in a short period of time, I have found that as long as I pay attention I can crank out ice faster with trays than an freezer-mounted ice maker can.
   / Ice maker use from freezer on fridge bottom topic #10
I'm sitting here drinking a glass of water from a door mounted exterior access ice maker on a bottom freezer fridge.
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
