Buying Advice Comments on a Kubota L 3901 with an LA 525 loader
   / Comments on a Kubota L 3901 with an LA 525 loader #1
Ivan49
Gold Member
Lake City Mi
Kubota L 3301
I have a few questions on this tractor. How good is it and is it trouble free. How is it on fuel? I stopped today at a dealer and got a price on one and I was surprized at my trade in value he offered me. I want one with the gear shift with the shuttle. He does not have one but has a load coming in around the first of May. On the loader I cannot find the lifting cap of it does anyone know? Now I have to decide if that is what I want as trhis dealer is much farther away than Deere or New Holland. Thanks for any help. Ivan
   / Comments on a Kubota L 3901 with an LA 525 loader #2
The lift capacity should be rated for 520 KG to full height.I am not sure if it is measured at the bucket center or at the bucket pins.The last 5 in 525 indicates the series of the loader.
   / Comments on a Kubota L 3901 with an LA 525 loader #3
I've got a 3901 with the 525 loader and I love it. I've got the hydrostatic trans which I wasn't sure about at first but after about 50 hrs of loader work, I can see why so many people like it. I say pull the trigger and you won't be disappointed.
   / Comments on a Kubota L 3901 with an LA 525 loader #4
There ain't a tractor made that is trouble free
   / Comments on a Kubota L 3901 with an LA 525 loader #5
I have a L3200... Same tractor before the tier 4 final emissions stuff.
The economy L tractors are HST or gear only I'm pretty sure, no shuttles. For a shuttle (GST) you need to move up to a Grand at 50% more cost (lots more bells, whistles & weight). I love the HST, so flexible & maneuverable. You loose 15% of your HP to it, but it is worth it if you do loader work, precision work or a lot of random utility work. Not as useful for field work so the 15% penalty isn't worth it for all applications. The HST trannys are as bulletproof as the gear ones. Maybe better if you figure in wearing out clutches.
I run about an gallon per hour doing most work. About a tank in a full days work. The loader is rated to 1,200lbs if I remember. I don't think that includes the bucket.
If you get one, get the rear tires loaded. Its not terribly safe, even with ballast on the 3pt when lifting hard with the loader. The loaded tires will keep the back end on the ground (you still need ballast or a heavy implement on the back). The L3200 is also traction limited, ballast helps there too. With my loaded R4s I'm about 50/50 on being traction or power limited now. Before loading I was always way traction limited.
Also get a loader with the SSQA on it. Makes it trivial to swap from bucket to forks. I probably use my forks more than my bucket.
Probably a non issue with the new model, but check for a jerky 3pt. Put a heavy implement on & try to raise it 1/2" a few times. Doesn't show lowering, without a heavy implement or moving large distances(several inches). Mine has an annoying jerky hitch, but I knew it when I bought it & bought it anyway (and would again). Some are rougher than others & it bothers some more than others. I hear fixing the root cause is about the only other change other than the emissions junk between the L3200 &L3301.
   / Comments on a Kubota L 3901 with an LA 525 loader #6
I believe they do offer a shuttle now on the basic L models.
   / Comments on a Kubota L 3901 with an LA 525 loader #7
Go to the brochures and you will find the specs.
   / Comments on a Kubota L 3901 with an LA 525 loader #9
I know the specs of the tractor but cannot find the lift cap of the loader. They do make a gear drive shuttle shift tractor also
Actually, The loader specs for the LA525 are in the link MtnView posted if you take the time to read it :rolleyes:
It's listed as 1,131 .lbs @ pivot pins and 855 .lbs 500 mm forward.
My bad I should have opened the link. I just assumed it was the same as the book on the tractor that I have. Thanks for correcting me
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
