   / Harbor Freight Tools that don't suck #4,491
Used to buy metric and SAE wrenches there to find one "close enough" for most fasteners. Things are getting better there.
   / Harbor Freight Tools that don't suck #4,492
My Predator splitter came Thrusday. I am really impressed with it.
   / Harbor Freight Tools that don't suck #4,493
   / Harbor Freight Tools that don't suck #4,494
Sweet!
Roger, what took you so long to put it together and split that wood? ;)
   / Harbor Freight Tools that don't suck #4,495
Sweet!
I had it together and was splitting wood within a few hours of getting it. I just had not posted the pics of it. This is why I was looking for a coupon that could be used on predator gas powered items. I was hoping to run it today but it did not happen.
   / Harbor Freight Tools that don't suck #4,497
Tools that don't suck: Somebody was talking about the needle scaler over on Welding Web.
This reminded me that I have this tool, and it saved the day when nothing else would work. The needles were small enough to clean out bad grout and tree roots around the septic entry pipe. No other tool, and I tried several, could get far enough into that tight circular gap. Its several years later now and the new grout remains watertight.
On welding web, the user complained that he had to sand down and smooth the piston before he could use the tool. But he said at one-sixth the cost of the comparable professional tool, it was cost effective. Mine worked out of the box and paid for itself right there. (But even after loading it with oil, when I went to use it a year later it was bound up and needed penetrating oil plus hammering on the piston to free it up).
Recommended.
138609d1251694554-cheap-air-chisel-removing-tiles-p1190583rneedlescaler-jpg
   / Harbor Freight Tools that don't suck #4,498
I have the needle scaler and have had good luck with it. It was used infrequently at work peening welds, but for very long periods at a time. Kept it well lubed and still runs strong. I would buy it again.
   / Harbor Freight Tools that don't suck #4,499
California, You still here?
OK, Power Auger. This is the third replacement, no extended warranty now. Seal between the gear box and motor leaking badly.
Have it apart if I can't remove the drum half of the centrifugal clutch, to replace the seal, if I can get one, I may fill it {the gear box} with solid grease and put it together and use it as long as it lasts. They work good for a while.
Richard
   / Harbor Freight Tools that don't suck #4,500
Richard
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
NEW Long Forks (A59000)
NEW Long Forks...
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
