FEL lines refuse to connect. Huh????
   / FEL lines refuse to connect. Huh???? #11
I think on mine when it happened the pressure was on the loader side, which is the female end. I couldn't get any pressure to release when it happened other than running cool water over the hydraulics.
You gents were right on the money. I actually gave it a gentle tap with a 3'8" extension wrapped in a rag, and they then slid right on. Thanks for the help. :)
   / FEL lines refuse to connect. Huh???? #13
I had to loosen one of the fittings on my grapple to ease the pressure once. Now I plug the two hoses together when I take it off of the tractor.
   / FEL lines refuse to connect. Huh???? #14
Not only do I plug them together I unplug them immediately to let a drop or two of oil "puke out" then plug them back in a final time to keep dirt out. I have never had a problem with the grapple. It was always loader hoses unplugged and then heat soaked, that I had trouble with. Or the loader just shifted a bit on the ground, and the pressure in the loader lines increased
   / FEL lines refuse to connect. Huh???? #15
+1 for the extension. I tap it with a hammer. Mine are all female, no option to hook together. I've got an idea for a tool that will hook around the bottom of the fitting and have a pivoting handle that will drive a pin into the valve. One of these days. I'll get around to making it
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
Unused 2025 CFG H15R Mini Excavator (A49461)
Unused 2025 CFG...
Vermeer SC802 (A50322)
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
