HONDA 6522 compact tractor,powershaft ,problem with transsmission
   / HONDA 6522 compact tractor,powershaft ,problem with transsmission #1
bojan
metlika
Honda 6522
Hi,I bought a honda 6522 year 1995,2200 hours.with mower deck and grassbox.seller told that tractor is in original genue working condition.When tractor come home,Does not mowe prperly.Somethimes do not start mowing,when you put transsmission in reverse go forward,PTO does not start working.After that I check oil.There was 3 L more oil than should be.I put it out.After that tractor work ok,mowing Ok,PTO worked fine.After 3 days I try again and again did not working ok?What could problem be.PLease reply if you have any idea.Thanks
   / HONDA 6522 compact tractor,powershaft ,problem with transsmission #2
I wonder if you have a leak somehow so diesel gets into your transmission? I don't know how that could happen but the extra 3l came from somewhere. Have you changed the fluids all around the tractor yet?
Jim
Jim
Not yet.But will do that.But I think that oil could be fixed by prewious owner.
Hi,I chabge new oil and nothing better.Still do not work Ok ANd do not engage PTO.Is it posible to be clutch?
   / HONDA 6522 compact tractor,powershaft ,problem with transsmission #5
I think you need to clean the oil tanker and then try again may this will solve your problem.
bumper
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A52577)
2002 WESTERN STAR...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
