Slick 50 grease
   / Slick 50 grease #1
Eric_Phillips
Rochester, NY
FarmTrac 270DTC
I have inherited a couple tubes of Slick 50 grease. I normally use a Moly-lithium grease. Will the slick 50 grease be compatible? I have a 27HP compact utility tractor.
   / Slick 50 grease #2
According to the MSDS, it is a lithium soap. You'll find this compatible thickener chart helpful, I think.
The Skinny on Grease Compatibility
Molybdenum disulfide would be a superior high pressure lubricant over PTFE.
   / Slick 50 grease
Thanks for the information. Maybe I will just use the slick 50 in the mower and Moly on the tractor and loader. Don't want to turn down a couple free tubes of grease if I don't have to.
   / Slick 50 grease #4
I havened heard "slick 50" in years. Seems like they used to make engine oil additives if I remember correctly.
   / Slick 50 grease #5
I think it was used originally in WWII...supposedly it could keep an aircraft flying even if the crankcase had been shot through and loss of oil pressure...not sure about this...but WWII vets I know is where I first heard about it...seems like it was something like $50 Qt....
   / Slick 50 grease #6
Quaint story - not even close to possibly being true.
Slick 50's claim to fame was that it had PTFE (Teflon) in it "The slickest substance known to man." Although PTFE was accidently created in 1938 as part of another experiment, DuPont didn't trademark "Teflon" until 1945, and the first products using Teflon didn't appear until 1946.
Slick 50 was first marketed in 1978 - obviously, that's long after WW II ended.
   / Slick 50 grease #7
I thought about "googling" the term before I posted the myth...
   / Slick 50 grease #8
   / Slick 50 grease #9
I use slick 50 on my tractor and snow blower. So far in no problem.3 years
   / Slick 50 grease #10
One of Slik 50's "sales aids" when I first heard of them was a small engine (5 hp Briggs?) that they would run with oil and Slik 50 in it, then drain the oil and run it dry for 10 or 15 minutes. Impressed a lot of my friends. They tried it and claimed decent gas mileage increases.
2014 CATERPILLAR 324EL EXCAVATOR (A52705)
2014 CATERPILLAR...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
New Holland C238 Compact Track Loader Skid Steer (A52377)
New Holland C238...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
