Aerosol Spray Paint Can Revival - Any Helpful Tips or Tricks ?
   / Aerosol Spray Paint Can Revival - Any Helpful Tips or Tricks ? #11
You can buy them off Amazon but most hardware stores that sell the can spray paint has extra nozzles you can buy.
I have a bag of them and once I empty a can if the nozzle is good I will put it on top of a can of WD-40 and spray until clean then put the nozzle in a bag and save. Just sometimes I can't remember where I put the bag:(
   / Aerosol Spray Paint Can Revival - Any Helpful Tips or Tricks ? #12
When done, I turn upside down and then spray until clear. Then I wipe the tip clean and that seems to be the key. I haven't had a plugged spray tip in several years.
I used to do that myself, but now it seems there are some spray cans that are made to spray upside down so that trick doesn't always work.
I never knew they sold replacements...I'll have to check it out.
As far as freezing goes, I leave my spray cans in the garage and haven't had a problem with them not working the next year...not uncommon to see -25 to 30 here in the winter.
   / Aerosol Spray Paint Can Revival - Any Helpful Tips or Tricks ? #13
I leave mine in an unheated garage. We've had many -10 morns this past winter. My cans still work years later after using the invert and clear method. I buy mostly Rustoleum.
My :2cents:
1265 (A50490)
1265 (A50490)
2006 TerraGator 8104 (A55301)
2006 TerraGator...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
Tradewinds Power Unit (A50120)
Tradewinds Power...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
