3015 HST Rear lift ...
   / 3015 HST Rear lift ... #1
hunter63
Kenosha, Wisconsin
Mahindra
Mahindra 3015 HST
After sitting all winter....fired up..... and rear links don't seem to want to lift the back blade high.
Seemed to be a bit better after running awhile......trans works fine.....bucket works fine.....just limited lift?
No evident leaks....
Level at transaxle dipstick a bit low.....
Is there some where else to check fluid levels?
   / 3015 HST Rear lift ... #2
Your lever and/or linkage from your 3 pt lever is probably binding up and not moving to the full raise position. Try spraying the lever and linkages for the 3pt with penatrating oil and working lever and linkage untill it frees up.
Thanks for the reply
I'm having a friend bring out my manuals from home....I'm out at the cabin.....For turkey hunting.
Not sure how much help they will be.....looking for a schematic on where lines go pump etc?
Is the fluid level dip stick on the transmission?......or is there another spot to check?
Kinda waswaZ thinking along the same lines.....gonna try that when the rain stops.
Just seem odd that everything works and the lever does seem tight and hard to move.
Working the levers and actually running it seems to have gotten more lift out of the links.
Manual didn't say that the hydrostatic drive and hydraulic run off the trans-axle.......same reservoir dip stick.
So fluid full at transmission on dip stick......need to re-spray linkages.
   / 3015 HST Rear lift ... #5
Yes the dipstick for the hydraulics/transmission is just between your legs when sitting on the machine in the transmssion. People sometimes, seem to forget to lube all the levers and linkages that move that dont have grese fittings. A little pb blaster and some spray white lithium will prevent alot of these types of problems.
That's the plan.....Thanks.
Part of my problem is that my dealer closed, so kinda left me hanging.
Owners manual doesn't make a lot of thing clear.
This seems to have helped the most......Thanks.
Thought I would stop back and report that after a good soaking and spraying grease in all the linkages, lift seems to be working much better.
Yeah, thanks again.
Way too many times there is no follow-up so thought I would post one.
2015 GMC Acadia SUV (A51694)
2015 GMC Acadia...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
12' CONTAINER (A51248)
