TZ24da starts but will not move
   / TZ24da starts but will not move #1
TZnightmare
Scandinavia WI
TZ24da that is down right now.Mahindra emax just purchased
Hello to all,I was moving dirt today with loader and after backing up I suddenly had no forward or reverse.I have checked fluid level and all linkages to pump.The tiller I had on has power to it as does loader and power steering.(history) I have been roto tilling for a few days to open up larger garden spaces and had no rpoblems till today when pushing a dirt bank down into a hole and as I said after backing up on one of the passes No forward or reverse. Any thoughts? Thanks
   / TZ24da starts but will not move #2
Check your sump filter, if you have one for blockage.
The HS filter is at the very bottom of rear trans and was recently changed as was fluid. The loader hydraulics work fine as does power steering.I also looked to make sure the linkage that comes from F-R pedal was actually turning the shaft that goes into hydraulic pump and it is.
To add update....on the off chance a hydraulic filter plugged I changed both Hyd filters and put new oil in.........no change,she won't move or even sound like she's trying.If anyone has any thoughts I sure would like to here them because it's starting to look like something let go down in side.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
Informational Lot - Shipping (A53472)
Informational Lot...
2015 JCB 550-170 Telehandler (A51573)
2015 JCB 550-170...
