Losing power, then it comes back
   / Losing power, then it comes back #11
I would look at the cheapest and easiest solution first, (the lazy in me dictates this) look at the fuel cap and whether or not it is venting properly.
   / Losing power, then it comes back #12
I'm having some issues with power loss. I'll be out mowing just fine with everything working perfectly, then the engine drops down to a rough idle. Surging up and down. I disconnect the PTO and take it out of gear and wait a couple of minutes. While this is happening, nothing happens when I push down on the peddle. It's like there isn't any fuel getting there and it's starving to get enough fuel to keep idling. Then everything comes back to normal and I'm back to mowing until the next time. This seems to be happening every ten to 45 minutes.
A couple years ago I replaced my mechanical fuel pump with a Mr Gasket electric diesel fuel pump. If it was the fuel pump, wouldn't it be constant? I'm at a loss why it happens, then starts working again on it's own.
I'm going to replace the filter, but also question how it could cause the problem, then work again without me doing anything?
This is on my Century 2535. But I doubt it has anything to do with brand.
Any advice would be greatly appreciated.
Thank you,
Eddie
I think the pleats on the filter are closing up due to the pressure across the filter under hi fuel fiow. ... Then they open back up as it idles. Repeat.
   / Losing power, then it comes back #13
Dont forget the Air Filter, as one item to look at. Do you have any noticeable un burnt fuel or low/hi fuel consumption>? That can help trace it down.
Mouse nest maybe too...
look for some screens in the banjo fittings and fuel ports for blockage as well.
M
I replaced the fuel lines and filters. I blew through all of them and they had no restriction at all. So then I checked the wiring on the fuel pump, which looked perfect. I then tried to fill up the new secondary fuel filter, which is a Wix clear plastic model, and it wouldn't work properly. I went online and looked at another Mr Gasket electric diesel fuel pump since they are $58 at the auto parts store. The reviews on Amazon are pretty bad, which is kind of what I'm experiencing with it. This is my second Mr Gasket fuel pump that I'm throwing away. The best reviews on Amazon where for the Airtex electric fuel pump. It's not rated for diesel, but a few people on there say they use it on their diesel engines with good results, so for half the cost of the Mr Gasket, I'm going to give it a try.
Eddie
   / Losing power, then it comes back #15
Eddie
If that doesn't work out for you Eddie, keep in mind that early 90's diesel pickups often had frame mounted lift-pumps.
Ex. a 92 Chev 1 ton. Don't know how the flow rate compares to what you need, and you may need some fitting adapters, but just wanted to bring up that option.
Rgds, D.
   / Losing power, then it comes back #16
I had a similar situation last weekend on my MF231.
I replaced the fuel filter last fall.
Out bushhogging the first time last weekend and I lost power to an idle a couple times, and then finally to nothing.
I got out and opened the fuel valve 4-5 more turns and hit the manual finger lift pump a few times. Turned over the ignition about a minute and it started fine. All has been well since with about four more hours use, no problems.
Amazon.com: Airtex E8016S: Automotive
The filter came in on a Monday and it was really simple to install. I wasn't sure if it would work for a diesel engine, but I received several replies from people on Amazon that said they used it on their tractors and it worked great. I've had it on there for 15 hours now and its working perfectly. No power loss and it even seems like I have a little more power. Everything seems smoother in the engine to me.
It might have been the filters or the hoses, but I really think it was the fuel pump.
Thank you,
Eddie
   / Losing power, then it comes back #19
Glad you have it fixed.
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
