Tororider
For your needs a new residential grade, or used commercial zero turn would serve your purpose well.
The above quote is from 2 years ago. Now my old Kubota lawnmower is broken again. I just can't figure out why a 20 year old lawn mower would keep breaking. The mower will barely move up a slight hill. I suppose the belt could need replacing. The tensioner pulley seems to be doing its job. However, it feels like the gear that moves the rear axle is worn.
Good suggestion. My wife is going to order the belt. I am optimistic that replacing it may fix the problem.Why not at least try a new belt?
If it were a gear, you certainty would know; they can't slip without grinding then it would stop altogether. Maybe replace the spring on the tensioner for good measure. Both should be inexpensive, & its not unusual that a belt would wear out after 2 years. They get a hard glaze & slip in the pulley. If performance improves temporarily when you spray on some belt dressing, you found your problem.
By throttle control, I simply mean increasing or decreasing the speed at which the engine runs - just like I can do on my log splitter, my riding mower, and the push mower I borrowed from my FIL. The MTD push mower manual says a throttle control is an option. See the picture of the manual below.It's standard that adjustment of carburetors on lawnmowers and weed eaters, chainsaws, etc. is NOT allowed. It's considered tampering with emissions controls and is strictly forbidden by the EPA, ESPECIALLY on lawnmowers, one of the most polluting devices known to man on planet Earth.
What exact planet do you live on that this comes as a surprise?:confused3::confused2:
Chim, you must really enjoy mowing. 2 1/4 acres was not enough yard for you so now you have 3 1/2 acres to mow. My place takes about 1 1/2 hours to mow with my Kubota when I mow the yard, the garden area, and the property entrance. You appear to be able to mow twice as much acreage than I mow in less time.Good to hear from you. I discovered your thread a little over a year ago, and thoroughly enjoyed your journey.
I've been happily using RFM's for over 20 years here at our place. Until a couple years ago I used 5' RFM's and it took 1-1/4 hours to do a little over 2-1/4 acres.
About two years ago we added 1-1/3 acres of yard, which puts the grass at about 3-1/2 acres. . While we were transforming the additional acreage into yard, I bought an L3200 with a 6'RFM. With the added grass, mowing time is still 1-1/4 hours.
The loaders I've had were very easy on/off, and I never mow with a loader on the tractor. With a loader on, there would be places that I couldn't get close enough without using a small walk-behind or way too much time with a string trimmer. A little creative mulching eliminates most trimming.
