Open center hydraulic question regarding a log splitter
   / Open center hydraulic question regarding a log splitter #1
HKH
Member
NY
NH Boomer 35, Kubota BX 1880
I have a NH tractor with any open center with two rear remotes. (boomer 35).
If I choose to run a log splitter, I planned on bungie tying the lever to get flow and use the valve on the splitter.
My question is will this setup cause an unnecessary heating of the fluid and damage my tractors pump? I read that it might, and I wanted to double check prior to buying the unit.
Thanks
   / Open center hydraulic question regarding a log splitter #2
I doubt it would damage the pump as the remote valve is just routing the flow to the log splitter valve.
You should run the tank line to tank and not back through the valve.
Your log splitter cycle time is related to pump GPM's, and that is determined by engine speed.
Thanks JJ for the response. Can you elaborate on this? What modifications would I need to do.
I always assumed that when running a 3pt splitter you just plugged it up to the remotes.
   / Open center hydraulic question regarding a log splitter #4
The reason is that back pressure from a valve downstream could damage the 500 psi tank line, so theoretically one should run the tank line directly to tank.
Most manufacturers suggest running tank lines to tank.
Some people do it and get away with it for a while and then you might hear something like, it work that way for two years, just don't know how or why it broke.
   / Open center hydraulic question regarding a log splitter #5
Bypass the splitter tank??
2023 John Deere 8R410 MFWD Tractor (A52128)
2023 John Deere...
Set of AG R4 Wheels and Tires (A52128)
Set of AG R4...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
2018 FORD EXPEDITION (A51406)
2018 FORD...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
