Where to tap in FEL / Backhoe hydraulics: Ford 1700
   / Where to tap in FEL / Backhoe hydraulics: Ford 1700 #1
bdoyle
Member
Nevada
78 Ford 1600 & 81 Ford 1700, 1980 Bobcat 720
I have a 1700 tractor that has evidence of having a front loader installed at one time. I just picked up a LW-6 backhoe and I was thinking about tapping into the 1700 hydraulics. But exactly where???
Thumbnail pics are Side view, Rear view and Front. The center block is a loop that previous owner had a cement mixer hooked to. Thinking I should just use external pump but then I have to hook the tank up.
   / Where to tap in FEL / Backhoe hydraulics: Ford 1700 #2
What happened if you just used the center block that the mixer was hooked to
   / Where to tap in FEL / Backhoe hydraulics: Ford 1700 #3
A backhoe with no loader to counterbalance it sounds like front wheels often in the air. Planning a loader as well?
Jim
Well, originally I thought the loader did not use the aluminum block but one of the other plugs. But anyway I did hook up the BH to the aluminum block and it works great. I did drag home a 770a loader today so now it all waiting to go together. I hope those blocks stack. Probably maxing out capacity on pump but I'll try it before going to pto pump.
As far as the light front end, you can pick up a wheel with one hand. I had to move out of the garage and had to stack three bags of concrete on the front frame. Even still the tires left no marks in the dirt, but I got it where it needed to be.
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2019 Bobcat E35I Mini Excavator (RIDE AND DRIVE) (A50774)
2019 Bobcat E35I...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
