International 46 Square Baler - Wheel Bearings or Bushings?
   / International 46 Square Baler - Wheel Bearings or Bushings? #1
dkw45
SW MO
Need a little advice or input.
I've been given an International 46 baler. It's been sitting in the barn for a few years, but was working fine when parked. The problem is, it's about 120 miles from me. I don't have a trailer capable of hauling it. I was debating putting good tires on it, repack or replace wheel bearings, then tow it home. The trip would be all rural roads and a slower speed would be fine.
Does anyone know whether or not the 46 has wheel bearings or bushings? My online searches haven't provided this info and I don't want to travel that far just to look for myself.
Any thoughts on my plan?
Thanks
I found my answer. It has bearings.
Now, should I try to tow it home or not?
   / International 46 Square Baler - Wheel Bearings or Bushings? #3
I found my answer. It has bearings. Now, should I try to tow it home or not?
Why not. Just take your time and service everything before you leave. Keep the speed down and take your time driving.
Chris
   / International 46 Square Baler - Wheel Bearings or Bushings? #4
I bought a Massey Ferguson 124 baler a few years ago that's the size of your IH 46. Towed it home about 30 miles using my 2001 F150 with no problems. Used the back roads, kept the speed around 25 mph and was careful to keep the right wheel out of the ditch. That 124 has a two-position swing hitch---one position for towing on the road, the other position for baling. I suppose your IH 46 has a similar setup.
Good luck.
   / International 46 Square Baler - Wheel Bearings or Bushings? #5
If you do a good job of servicing the bearing and the tires are good, there's no reason why you can't tow it at decent speeds. I would air the tires up to maximum pressure allowed...nothing builds heat in a tire like flexing the sidewalls from running low air pressure and excess heat is very damaging to tires.
   / International 46 Square Baler - Wheel Bearings or Bushings? #6
I would assume that baler has grease fittings in the hubs. I would carry a grease gun with you. Make sure you know how to pack barrings before you go. I have a lisky barring packer that I love, much easier than the palm of the hand method.
   / International 46 Square Baler - Wheel Bearings or Bushings? #7
I have a new holland 67 with wheel bushings but I pulled it 50 miles and burned up the bushings and now need new bushings... I wish I brought with a trailer
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
7022 (A50322)
7022 (A50322)
UNUSED AGT ATK-B1000 2 POST CAR LIFT (A51248)
UNUSED AGT...
2017 International DuraStar 4300 Truck (A51692)
2017 International...
2023 JOHN DEERE 8R370 LOT NUMBER 207 (A53084)
2023 JOHN DEERE...
UNUSED FUTURE BD43 HYD BACKHOE ATTACHMENT (A51248)
UNUSED FUTURE BD43...
