MF TO-35 front axle beam
   / MF TO-35 front axle beam #1
Neutant
Fredon, NJ
M/F TO35
I have to replace the bushing on the front axle beam. Pin is worn, part of bushing is gone. Axle looks good - will braze the small worn area on the beam if needed.
Question is about the bushing. The beam is 1 1/2" thick so the 3/4 inch bushing only supports half the beam as engineered. wonder if that is good enough or could I improve it by installing bushings from both sides or something? This tractor has a front bucket on it.
   / MF TO-35 front axle beam #2
G'day yes that was common when rebushing to put one in from both sides, the pin is hardened so I wouldn't braze new pins are avail aftermarket for not a lot of money
Jon
Jon
Thanks banjo, I meant brazing the small worn area on the axle beam if need be. I found a full 1 1/2" bushing on ebay. bought their last one.
   / MF TO-35 front axle beam #4
G'day no worries my bad did not read your post properly
Jon
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
1706 (A54756)
1706 (A54756)
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
LOAD OUT AND SHIPPING (A54865)
LOAD OUT AND...
