sickle bar mower question
   / sickle bar mower question #1
rbig
Member
I am a bit confused about sickle bar mowers. Some say you can't mow downward unless you have a wobble drive. Others say a pitman drive can mow downward.
I have a ditch across the front of our place. It's mostly 10' high, and comes down at an angle of maybe 60 degrees. I am no longer able to do weedwhacking to keep it looking nice. That pretty much leaves sickle bar mowers----- go across it mowing up, and go across it mowing down.
What are the rules on whether you can mow downward with sickle bar mowers? All accounts say you do mowing from 0 to 90 degrees upward with either. It's the downward thing I need to know the rules on.
   / sickle bar mower question #2
With a wobble drive you can mow in any orientation that the lift mechanism will allow.
With a pitman stick type drive the side to side motion of the sickle is optimum with the mower bar perfectly horizontal with the mower frame. The mower bar can angle up or down to some extent but the more it does the higher the stress on the pitman stick and drive unit. There is really no hard limit as it depends on what you are trying to cut. As a practical limit I would say +/- 25 degrees from horizontal. You usually can hear the drive binding.
How you drive to cut it can make a big difference. For instance when I was using a JD 37 mower that had a pitman stick to mow a ditch I some times would only take a half of a cut on the first pass so on the next pass I could drop a wheel off the edge of the road to angle the frame to allow the mower bar to lie down.
   / sickle bar mower question #3
I see no way for you to get a pitman drive mower to swing up or down 60 degrees. I would just look for a belt drive. Think about how a pitman works and you will see that it would be in bind to say the least. Even if you got it to work it would be doing what it is not designed to do and the stress would shorten the life of parts.
   / sickle bar mower question #4
All accounts are wrong. :)
Bruce
   / sickle bar mower question #5
I had a co-worker with a similar bank. He used a regular push mower. He took the handle off and attached a rope. He would stand at the top of the bank and let the mower down with the rope then pull it up. Move over and do it again. Seemed to work good.
Just an idea as I don't know what your limitations are.
gg
   / sickle bar mower question #6
I have a new holland 451 sickle mower ,and I can tell you from experience ( by accident) it will mow in any position you can put it in, even folded up in transport position. Although it is a belt drive.
I would think the a pitman arm mower would not stand the mowing you are talking about for long. Most places I have seen a pitman break is when going around the outside of a field trimming steep areas ,in comparison to the tractor.
   / sickle bar mower question #7
As most have stated a pitman style mower is very limited to angle , I bought a IH 1300 balance head and added a hydraulic cylinder to mow banks, ponds, and such. It will mow from straight vertical, to way below horizontal, not sure how far cause I've not had to max it out. Plenty of ideas and reading if you search around on here about ditch bank mowing and such. Good luck with your project.
   / sickle bar mower question #8
I just bought a Frontier SB3108 Sickle Bar mower and love it. It can cut down to 75 degrees and up to 90 degrees.
  • Frontier Sickle Bar Mowers.pdf
   / sickle bar mower question #9
They make a nice sickle I just am to tight to spend that much on one. :) I've yet to max mine out on down travel , it's had no trouble reaching down were I've needed so far. Here is a quick snap shot of one of the banks I have to do , even with the tractor setting on top level it's no where near maxed down angle.
   / sickle bar mower question #10
The cylinder sets the angle of the sickle bar, i.e. that is what brings it vertical?
2022 Polaris Sportsman 570 4x4 ATV (A48082)
2022 Polaris...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
2002 Hurricane 196FF Fun Deck 19ft Deck Boat with 23ft T/A Boat Trailer (A48082)
2002 Hurricane...
2016 Chevrolet Traverse LS SUV (A50860)
2016 Chevrolet...
2022 Club Car...
