Learned what happens when sand and water mix
   / Learned what happens when sand and water mix #11
That's how we learn. ;)
   / Learned what happens when sand and water mix #12
So where did the water come from? You hit spring or something?
   / Learned what happens when sand and water mix #13
Looks like it's only half stuck. Half of it is still visible!!! :)
Eddie
No it was really too wet to box blade but I went back one more time for that last little spot ....
   / Learned what happens when sand and water mix #15
I have a friend that was a Marine combat engineer in Vietnam. The tanks would get stuck in the rice paddy mud at times and with their flat bottoms the suction was too much for any piece of equipment to pull them out. He said that they would push a piece of C4 under the tank, hook it to another tank, get them both "pulling" and then set off the C4. It would pop them up in the air just enough to break the suction and they would pull them out.
Don't try this with your tractor :D
Thought about a compressor and air lance
   / Learned what happens when sand and water mix #18
   / Learned what happens when sand and water mix #19
It's always that "last spot" you get stuck in. :rolleyes:
I have been stuck many times trying to mow that last spot so I didn't have to weedeat.
   / Learned what happens when sand and water mix #20
My boss did that with a JD 440 skidder
Utility Trailer (A52377)
Utility Trailer...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2013John Deere 244J (A47477)
2013John Deere...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Engel 20' Boat (A50121)
Engel 20' Boat...
