Good morning!!!!
   / Good morning!!!! #33,541
Eric sorry about your troubles but glad you got the lamb out of the water and all patched up. I'll bet the water was cold
   / Good morning!!!! #33,542
61 when I left for a city job, mid 80's expected today. Not much going on here. Waiting until Friday, might come into the city for the WWII flyover. That should be impressive, especially with the great weather. Torn between witnessing take-offs or coming to the city on a Friday. What to do?
   / Good morning!!!! #33,543
As personally I am fascinated by WWII vintage aircraft know where I would be. The B17 in flight is something to behold plus the P51 mustang
   / Good morning!!!! #33,544
Last I checked, over 50 WWII aircraft will do the flyover in various formations. I guess this is a once in my lifetime event. 70th VE commemoration day too, sounds like I am trekking to the city.
   / Good morning!!!! #33,545
59 this morning and headed to 85 today. Well the dentist went as well as it could. I complained of some pain from the last filling. He checked and said the filling was left too high. Done in same office but different dentist. He was out sick so his wife (the other dentist) filled in. He fixed it before starting the new one yesterday. Now that's something I couldn't do. Work with my wife.
Back to chicken coop for more fun in the chit or is it supposed to be sun. Hmmmmm.
   / Good morning!!!! #33,546
Good Morning. 0730, sunny, 65F with 97% humidity. Forecast high of 85F with 0% chance of rain today, and a low of 62F tonight. Either garden or waterlines are on tap today. Or maybe both if everything goes smoothly with the waterline laying. I need to get back to it so I can fill the trenches and mow that area.
Eric, glad the lamb made it through the scrap. And about the phone, there are kids in China whose job's depend on folks doing what you did.
   / Good morning!!!! #33,547
48 and sunny with a high of 70 Today.It looks to be a nice Day to work in the Yard.
   / Good morning!!!! #33,548
Eric, It sounds like you have a Champion lamb, and a useless dog. Time to ship him off to the city. And you needed a new phone anyway, now you can get one to take really good tractor pics.
   / Good morning!!!! #33,550
Happy Cinco de Mayo! Quiet day here. In the office all day, for once. Got up early (5:30 a.m.) to get stuff done. Already pushed out a bunch of things. Taking a little internet break, then back to it. Have a 2.5 hour web class for work starting at noon. Rain coming, so they say.
Have a great day, everyone.
   / Good morning!!!! #33,553
A little cooler today, 48F on rising, going to 81F this afternoon. A low pressure system is working its way down from Alaska over the next couple of days, and that could bring us some showers tomorrow and Friday.
Eric, congratulations on your Superman rescue of the lamb, and your doctoring afterwards. You're a man of many talents. Don't give up on that cell phone until it's spent a few days on the dash of a car in the sun. I had one that took a week of that before it worked, but only after I'd fully charged the battery. First thing the water does is short out the battery, so it's liable to be completely flat. DAMHIKT And if it doesn't revive, perhaps the collie owner would sponsor a replacement?
I was also surprised with how well a 4 1/2" grinder with that diamond blade cut not just slate, but granite and porcelain tile as well. If it would reach all the way through from one side of that slate slab you've got, I wouldn't hesitate to just do the job with that and not have any rough edges to worry about. And you'd be amazed what the same tool will do to steel with an abrasive cutoff wheel, or with a knotted wire brush on rust.
Farmer, sounds like you're making good progress on the coops, and are over the worst at the dentist.
Yesterday I turned a piece of scrap bar stock down to fit the newly bored holes in the side plates to check alignment. One piece slipped through nicely with the 0.003" clearance between the parts, the other had about 0.010" of offset from side to side. Looking closely at the two sides, they've been bent out of alignment. A little persuasion from the hydraulic press and machinist's jack got them a little closer, and another dose of persuasion with a dead blow hammer got the pin fully seated. The pin doesn't pivot in those bores, so an interference fit like this may actually be a good thing.
Spent the rest of the afternoon working on the bushings, two at just over 3", the other four a bit longer than an inch. The bore on the D.O.M. tube I purchased is just a few thousandths under the nominal 0.125" I'd like to use for the pins, it's oval, and it just barely cleaned up at 0.127". Not great, but I can cheat a bit on over sizing the pins. Had more trouble holding the OD dimension, and wasn't able to get a consistent 0.001" of interference. In fact I got no interference at all. I suspect that the tool holder is just a bit low and is being pulled into the work resulting in inconsistent amounts being taken off for the same amount of tool advance. The stuff also isn't the best machining material in the world as it tends to tear instead of cut cleanly. So I'll be reading up a bit this morning in hopes of finding some speeds'n'feeds that'll give better results.
Happy Cinco de Mayo, everyone. Around here it's a good idea to stay inside and dodge the celebratory gunshots into the sky. What goes up, must come down, somewhere...
   / Good morning!!!! #33,554
66°F and .31 inches rain last 24 hours
Be safe
Have a great day
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #33,555
Well now you put it that way, I feel a whole lot better :)
   / Good morning!!!!
Rainy here today, let the dogs out, have to towel them off after they come in. Needed the rain, it's been pretty dry here.
   / Good morning!!!! #33,557
Rainy here today, let the dogs out, have to towel them off after they come in. .
And thus we have the answer to the long unaswered musical question, "Who let the dogs out."
Thank you for clearing that up.
If we can now get Kenneth to inform us of the frequency, I think a lot of things will fall into place.
   / Good morning!!!! #33,560
That's a good project. My loader pins on the bucket, not so much on the loader mounting, are sloppy as heck too. Not built with bushings and the pins are harder than the sleeves they ride in--of course.
Bushings will be something I'll be looking for on the next tractor. I've been lucky on this project to be able to disassemble everything far enough to get it under the mill for boring, but I don't know how you'd do that for a FEL bucket with the pivots welded on. Probably have to fabricate new brackets (bushed, of course), and replace the old ones.
Haven't measured the pins yet, but there are obvious wear marks on them as well. The DOM tubing I'm using for the bushings is 1020 carbon steel, and I suspect that the pin material is A36 as it was being used as a tensioning rod in an earthquake retrofit project. No idea how they'll wear together, but you can bet I'll be using a lot of grease!
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2020 CATERPILLAR 302.7D CR EXCAVATOR (A60429)
2020 CATERPILLAR...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
