Building a terraced road/trail across a slope
   / Building a terraced road/trail across a slope #11
The tool for the job is a turn plow. Ease along the top side with the plow throwing the soil down hill. Do that a couple of times and then go back with a road blade or box blade and you are done. I have seen it done by my dad and it worked well. Very well, and quick.
I like that idea. What about one of those old one-bottom plows (walk behind) and have a friend pull it with a winch. Make a couple passes & maybe the tractor can do the rest. Gotta use your tractor; it costs you money to NOT use your eqpt.
   / Building a terraced road/trail across a slope #12
I did it the way you propose. Tilted the box blade, backed in from level, worked three feet at a time; until the pucker factor was reduced. At that point you can work longer sections either in this orientation or turn around.
Oh yes, had the rippers down on the high side but none on the low side.
Dan
Thanks to you all, I've got a number of options to try so I'm going to try and get to it this weekend. I'm also going to thin out that section of woods a bit as well so I can get enough sunlight in there to get some grass growing as well to prevent erosion. Wish me luck.
   / Building a terraced road/trail across a slope #14
That would work, just watch for roots and rocks.
   / Building a terraced road/trail across a slope #15
We just did about exactly the same thing on our "back 40" on the steep slope down to the creek/ponds. Had a road cut snaking down and then across then down again to the bottom. A guy with a big excavator did the job in two hours. All trees tipped over with their roots, so no stumps, and he was able to run those big full buckets of dirt over to wherever we needed extra dirt (a lot of places when you live on sloped land) and even smooth them out a bit. We got a whole lot done in a couple hours for a few hundred bucks, without the pucker factor. There will still be hours of fun waiting for you and your tractor doing the fine grading, putting in a ditch and a crown, smoothing out any gouges from the tracks, dragging out the downed trees, etc., etc. JMO
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
Toro Reelmaster 3100D Reel Mower (A50121)
Toro Reelmaster...
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
2015 Chrysler 200 Sedan (A50324)
2015 Chrysler 200...
